Object-Oriented Type Inference, OOPSLA'91, pp.146-161 ,
DOI : 10.7146/dpb.v20i345.6575
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.136.9764
Type test elimination using typeflow analysis, Proceedings of Programming Languages and System Architectures, pp.137-150, 1994. ,
DOI : 10.1007/3-540-57840-4_29
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.43.2552
Optimization of Object-Oriented Programs Using Static Class Hierarchy Analysis, p.95 ,
DOI : 10.1007/3-540-49538-X_5
Type inference of SELF: Analysis of objects with dynamic and multiple inheritance, Software: Practice and Experience, vol.4, issue.9, pp.975-995, 1995. ,
DOI : 10.1002/spe.4380250903
Fast Static Analysis of C++ Virtual Function Calls, OOPSLA'96, pp.324-341, 1996. ,
Type inference for late binding: The SmallEiffel Compiler, JMLC'97, pp.67-81 ,
DOI : 10.1007/3-540-62599-2_31
URL : https://hal.archives-ouvertes.fr/inria-00563353
Efficient Dynamic Dispatch without Virtual Function Tables. The SmallEiffel Compiler, p.97 ,
URL : https://hal.archives-ouvertes.fr/inria-00565627
Declaring and Checking Non-null Types in an Object-Oriented Language, pp.302-312, 2003. ,
Static determination of dynamic properties of programs, 2nd Int. Symp. on Programming, 1976. ,
A fresh look at optimizing array bound checking, PLDI 1990, pp.272-282, 1990. ,
DOI : 10.1145/93548.93581
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.85.5471
A reexamination of ???Optimization of array subscript range checks???, ACM Transactions on Programming Languages and Systems, vol.17, issue.2, pp.217-227 ,
DOI : 10.1145/201059.201063
Predicate abstraction for software verification, pp.191-202, 2002. ,
A Symbolic Approach to Predicate Abstraction, pp.141-153, 2003. ,
DOI : 10.1007/978-3-540-45069-6_15
A static analyser for large safety-critical software. PLDI, 2003. ,
Indexed Predicate Discovery for Unbounded System Verification, LNCS, vol.3114, pp.135-147, 2004. ,
DOI : 10.1007/978-3-540-27813-9_11
What's decidable about arrays? VMCAI 06, LNCS, vol.3855, pp.427-442, 2006. ,
Path invariants. PLDI, pp.300-309, 2007. ,
Array Abstractions from Proofs, LNCS, vol.4590, pp.193-206, 2007. ,
DOI : 10.1007/978-3-540-73368-3_23
What else is decidable about arrays?, FOSSACS 2008, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-01418914
Discovering Properties about Arrays in Simple Programs. PLDI, pp.339-352, 2008. ,
DOI : 10.1145/1375581.1375623
URL : https://hal.archives-ouvertes.fr/hal-00288274
The Annotated C++ Reference Manual, 1990. ,
The Direct Cost of Virtual Function Calls in C++, OOPSLA'96, pp.306-323, 1996. ,
Lisaac: the power of simplicity at work for operating system. TOOLS Pacific, pp.45-52, 2002. ,
Adding external iterators to an existing Eiffel class library. TOOLS Pacific'99, pp.188-199 ,
URL : https://hal.archives-ouvertes.fr/inria-00098784
Garbage Collection, 1996. ,
Compiler Support to Customize the Mark and Sweep Algorithm, pp.154-165 ,
