Dimension reduction in functional regression with applications, Computational Statistics & Data Analysis, vol.50, issue.9, pp.2422-2446, 2006. ,
DOI : 10.1016/j.csda.2004.12.007
URL : https://hal.archives-ouvertes.fr/hal-00103266
A gauss implementation of multivariate sliced inverse regression, Computational Statistics, vol.12, pp.355-372, 1997. ,
Sliced Inverse Regression (SIR): an appraisal of small sample alternatives to slicing, Computational Statistics, vol.12, pp.109-130, 1997. ,
Optimal quantization applied to sliced inverse regression, Journal of Statistical Planning and Inference, vol.142, issue.2, pp.481-492, 2012. ,
DOI : 10.1016/j.jspi.2011.08.006
A chi-square test for dimensionality with non-Gaussian data, Journal of Multivariate Analysis, vol.88, issue.1, pp.109-117, 2004. ,
DOI : 10.1016/S0047-259X(03)00056-3
Some extensions of multivariate sliced inverse regression, Journal of Statistical Computation and Simulation, vol.15, issue.1, pp.1-17, 2007. ,
DOI : 10.1080/10629360600687840
A bootstrap method for assessing the dimension of a general regression problem, Statistics & Probability Letters, vol.77, issue.3, pp.247-255, 2007. ,
DOI : 10.1016/j.spl.2006.07.020
Retrieval of Mars surface physical properties from OMEGA hyperspectral images using regularized sliced inverse regression, Journal of Geophysical Research, vol.20, issue.2, 2009. ,
DOI : 10.1029/2008JE003171
URL : https://hal.archives-ouvertes.fr/inria-00276116
A Note on Sliced Inverse Regression with Regularizations, Biometrics, vol.21, issue.3, pp.982-986, 2008. ,
DOI : 10.1111/j.1541-0420.2008.01080.x
URL : https://hal.archives-ouvertes.fr/inria-00180496
Gaussian Regularized Sliced Inverse Regression, Statistics and Computing, vol.5, issue.22, pp.85-98, 2009. ,
DOI : 10.1007/s11222-008-9073-z
URL : https://hal.archives-ouvertes.fr/inria-00180458
Estimating the structural dimension of regressions via parametric inverse regression, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.63, issue.2, pp.393-410, 2001. ,
DOI : 10.1111/1467-9868.00292
A Sliced Inverse Regression Approach for a Stratified Population, Communications in statistics -Theory and methods 40, pp.1-22, 2011. ,
DOI : 10.1214/aos/1032526955
Can SIR be as popular as multiple linear regression?, Statistica Sinica, vol.8, pp.289-316, 1998. ,
Robust estimation of dimension reduction space, Computational Statistics & Data Analysis, vol.51, issue.2, pp.545-555, 2006. ,
DOI : 10.1016/j.csda.2005.11.001
On the Interpretation of Regression Plots, Journal of the American Statistical Association, vol.41, issue.425, pp.177-189, 1994. ,
DOI : 10.1214/aos/1176347254
Principal Hessian Directions Revisited, Journal of the American Statistical Association, vol.18, issue.441, pp.84-100, 1998. ,
DOI : 10.1080/01621459.1998.10474090
Save: a method for dimension reduction and graphics in regression, Communications in Statistics - Theory and Methods, vol.41, issue.9-10, pp.2109-2121, 2000. ,
DOI : 10.2307/2290640
Regression Graphics: Ideas for Studying Regressions Through Graphics, 2009. ,
Dimension reduction for conditional mean in regression, The Annals of Statistics, vol.30, issue.2, pp.450-474, 2002. ,
DOI : 10.1214/aos/1021379861
Reweighting to Achieve Elliptically Contoured Covariates in Regression, Journal of the American Statistical Association, vol.21, issue.426, pp.592-599, 1994. ,
DOI : 10.1002/0471725218
A Model-Free Test for Reduced Rank in Multivariate Regression, Journal of the American Statistical Association, vol.98, issue.462, pp.340-351, 2003. ,
DOI : 10.1198/016214503000134
South Pole of Mars: Nature and composition of the icy terrains from Mars Express OMEGA observations, Planetary and Space Science, vol.55, issue.1-2, pp.113-133, 2007. ,
DOI : 10.1016/j.pss.2006.05.035
Slicing Regression: A Link-Free Regression Method, The Annals of Statistics, vol.19, issue.2, pp.505-530, 1991. ,
DOI : 10.1214/aos/1176348109
Sliced inverse regression in reference curves estimation, Computational Statistics & Data Analysis, vol.46, issue.1, pp.103-122, 2004. ,
DOI : 10.1016/S0167-9473(03)00141-5
URL : https://hal.archives-ouvertes.fr/hal-00724646
An asymptotic theory for SIR? method, Statistica Sinica, vol.13, pp.297-310, 2003. ,
On almost Linearity of Low Dimensional Projections from High Dimensional Data, The Annals of Statistics, vol.21, issue.2, pp.867-889, 1993. ,
DOI : 10.1214/aos/1176349155
Entropy-based sliced inverse regression, Computational Statistics & Data Analysis, vol.67, pp.105-114, 2013. ,
DOI : 10.1016/j.csda.2013.05.017
Nearest neighbor inverse regression, The Annals of Statistics, vol.27, issue.2, pp.697-731, 1999. ,
DOI : 10.1214/aos/1018031213
An Asymptotic Theory for Sliced Inverse Regression, The Annals of Statistics, vol.20, issue.2, pp.1040-1061, 1992. ,
DOI : 10.1214/aos/1176348669
Bagging versions of sliced inverse regression. Communications in statistics -Theory and methods 39, 1985. ,
URL : https://hal.archives-ouvertes.fr/hal-00389125
Cluster-based Sliced Inverse Regression, Journal of the Korean Statistical Society, vol.39, issue.2, pp.251-267, 2010. ,
DOI : 10.1016/j.jkss.2009.08.004
URL : https://hal.archives-ouvertes.fr/hal-00547252
On a Projective Resampling Method for Dimension Reduction With Multivariate Responses, Journal of the American Statistical Association, vol.103, issue.483, pp.1177-1186, 2008. ,
DOI : 10.1198/016214508000000445
Sliced Inverse Regression for Dimension Reduction, Journal of the American Statistical Association, vol.13, issue.414, pp.316-342, 1991. ,
DOI : 10.1214/aos/1176345514
On Principal Hessian Directions for Data Visualization and Dimension Reduction: Another Application of Stein's Lemma, Journal of the American Statistical Association, vol.13, issue.420, pp.1025-1039, 1992. ,
DOI : 10.1002/9780470316818
Dimension Reduction for Multivariate Response Data, Journal of the American Statistical Association, vol.98, issue.461, pp.99-109, 2003. ,
DOI : 10.1198/016214503388619139
Sparse Sliced Inverse Regression, Technometrics, vol.48, issue.4, pp.503-510, 2006. ,
DOI : 10.1198/004017006000000129
Sliced Inverse Regression with Regularizations, Biometrics, vol.67, issue.1, pp.124-131, 2008. ,
DOI : 10.1111/j.1541-0420.2007.00836.x
A graphical tool for selecting the number of slices and the dimension of the model in SIR and SAVE approaches, Computational Statistics, vol.98, issue.1, pp.103-125, 2012. ,
DOI : 10.1007/s00180-011-0241-9
URL : https://hal.archives-ouvertes.fr/hal-00938090
Sliced inverse regression for multivariate response regression, Journal of Statistical Planning and Inference, vol.139, issue.8, pp.2656-2664, 2009. ,
DOI : 10.1016/j.jspi.2008.12.006
Consistent estimation of the dimensionality in sliced inverse regression, Annals of the Institute of Statistical Mathematics, vol.93, issue.2, pp.257-271, 2008. ,
DOI : 10.1007/s10463-006-0106-0
Influence Functions for Sliced Inverse Regression, Scandinavian Journal of Statistics, vol.5, issue.3, pp.385-404, 2005. ,
DOI : 10.1111/1467-9868.03411
Implications of influence function analysis for sliced inverse regression and sliced average variance estimation, Biometrika, vol.94, issue.3, pp.585-601, 2007. ,
DOI : 10.1093/biomet/asm055
An asymptotic theory for Sliced Inverse Regression Communications in statistics -Theory and methods 26, pp.2141-2171, 1997. ,
Sliced inverse regression under linear constraints Communications in statistics -Theory and methods 28, pp.2367-2393, 1999. ,
POOLED SLICING METHODS VERSUS SLICING METHODS, Communications in statistics -Simulation and Computation, pp.489-511, 2001. ,
DOI : 10.1093/biomet/58.1.105
Asymptotics for pooled marginal slicing estimator based on <mml:math altimg="si1.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:msub><mml:mrow><mml:mi>SIR</mml:mi></mml:mrow><mml:mrow><mml:mi>??</mml:mi></mml:mrow></mml:msub></mml:math> approach, Journal of Multivariate Analysis, vol.96, issue.1, pp.117-135, 2005. ,
DOI : 10.1016/j.jmva.2004.10.003
Determining the Dimensionality in Sliced Inverse Regression, Journal of the American Statistical Association, vol.16, issue.425, pp.141-148, 1994. ,
Class prediction and gene selection for DNA microarrays using regularized sliced inverse regression, Computational Statistics & Data Analysis, vol.52, issue.1, pp.438-451, 2007. ,
DOI : 10.1016/j.csda.2007.02.005
Model-based SIR for dimension reduction, Computational Statistics & Data Analysis, vol.55, issue.11, pp.3010-3026, 2011. ,
DOI : 10.1016/j.csda.2011.05.006
-Means Inverse Regression, Technometrics, vol.46, issue.4, pp.421-429, 2004. ,
DOI : 10.1198/004017004000000437
Partial central subspace and sliced average variance estimation, Journal of Statistical Planning and Inference, vol.139, issue.3, pp.952-961, 2009. ,
DOI : 10.1016/j.jspi.2008.06.002
The sliced inverse regression algorithm as a maximum likelihood procedure, Journal of Statistical Planning and Inference, vol.139, issue.10, pp.3570-3578, 2009. ,
DOI : 10.1016/j.jspi.2009.04.008
Asymptotic Inference for Eigenvectors, The Annals of Statistics, vol.9, issue.4, pp.725-736, 1981. ,
Kernel Sliced Inverse Regression with Applications to Classification, Journal of Computational and Graphical Statistics, vol.17, issue.3, pp.590-610, 2008. ,
DOI : 10.1198/106186008X345161
An adaptive estimation of dimension reduction space, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.24, issue.3, pp.363-410, 2002. ,
Moment-based dimension reduction for multivariate response regression, Journal of Statistical Planning and Inference, vol.136, issue.10, pp.3675-3688, 2006. ,
DOI : 10.1016/j.jspi.2005.01.011
Iterative optimal sufficient dimension reduction for conditional mean in multivariate regression, Journal of Data Science, vol.7, pp.267-276, 2009. ,
On Sliced Inverse Regression With High-Dimensional Covariates, Journal of the American Statistical Association, vol.101, issue.474, pp.630-643, 2006. ,
DOI : 10.1198/016214505000001285
On spline approximation of sliced inverse regression, Science in China Series A: Mathematics, vol.36, issue.9, pp.1289-1302, 2007. ,
DOI : 10.1007/s11425-007-0085-5
Dimension Reduction in Regressions Through Cumulative Slicing Estimation, Journal of the American Statistical Association, vol.105, issue.492, pp.1455-1466, 2010. ,
DOI : 10.1198/jasa.2010.tm09666
On dimension reduction in regressions with multivariate responses, Statistica Sinica, vol.20, pp.1291-1307, 2010. ,
Asymptotics for kernel estimate of sliced inverse regression, The Annals of Statistics, vol.24, issue.3, pp.1053-1068, 1996. ,
Asymptotics of sliced inverse regression, Statistica Sinica, vol.5, pp.727-736, 1995. ,
On hybrid methods of inverse regression-based algorithms, Computational Statistics & Data Analysis, vol.51, issue.5, pp.2621-2635, 2007. ,
DOI : 10.1016/j.csda.2006.01.005
