New interface
Journal articles
Continuous interior penalty finite element method for the time-dependent Navier-Stokes equations: space discretization and convergence
Erik Burman 1 Miguel Angel Fernández 2
2 REO - Numerical simulation of biological flows
LJLL - Laboratoire Jacques-Louis Lions, Inria Paris-Rocquencourt, UPMC - Université Pierre et Marie Curie - Paris 6
Abstract : This paper focuses on the numerical analysis of a finite element method with stabilization for the unsteady incompressible Navier-Stokes equations. Incompressibility and convective effects are both stabilized adding an interior penalty term giving L^2-control of the jump of the gradient of the approximate solution over the internal faces. Using continuous equal-order finite elements for both velocities and pressures, in a space semi-discretized formulation, we prove convergence of the approximate solution. The error estimates hold irrespective of the Reynolds number, and hence also for the incompressible Euler equations, provided the exact solution is smooth.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-00715243
Contributor : Miguel Angel Fernández Connect in order to contact the contributor
Submitted on : Friday, July 6, 2012 - 3:23:05 PM
Last modification on : Friday, January 21, 2022 - 3:21:22 AM
Links full text
Identifiers
Citation
Erik Burman, Miguel Angel Fernández. Continuous interior penalty finite element method for the time-dependent Navier-Stokes equations: space discretization and convergence. Numerische Mathematik, 2007, 107 (1), pp.39-77. ⟨10.1007/s00211-007-0070-5⟩. ⟨hal-00715243⟩
Share
Metrics
Record views
113
