Data assimilation in glaciology - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this short paper, we will give one example of an inverse problem in glaciology. This problem is fairly simple to state: how to infer a climatic scenario (i.e. how to reconstruct past polar temperature) from ice volume records? The idea of this work is to explore the ability of the adjoint method to solve the inverse problem of reconstructing past temperature given all available observations. We start here with a simplified ice-sheet model and perform twin experiments.
maelle_DAglacio.pdf (200.92 Ko) Télécharger le fichier
hal-00715832 , version 1 (09-07-2012)
  • HAL Id : hal-00715832 , version 1
Bertrand Bonan, Maëlle Nodet, Olivier Ozenda, Catherine Ritz. Data assimilation in glaciology. Advanced Data Assimilation for Geosciences, May 2012, Les Houches, France. ⟨hal-00715832⟩
623 Consultations
321 Téléchargements
