Computational results of a semidefinite branch-and-bound algorithm for k-cluster - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computers and Operations Research Année : 2016
This computational paper presents a method to solve k-cluster problems exactly by intersecting semidefinite and polyhedral relaxations. Our algorithm uses a generic branch-and-bound method featuring an improved semidefinite bounding procedure. Extensive numerical experiments show that this algorithm outperforms the best known methods both in time and ability to solve large instances. For the first time, numerical results are reported for k-cluster problems on unstructured graphs with 160 vertices.
manuscript_COR3.pdf (300.22 Ko) Télécharger le fichier
hal-00717212 , version 1 (12-07-2012)
hal-00717212 , version 2 (13-07-2012)
hal-00717212 , version 3 (13-07-2012)
hal-00717212 , version 4 (13-07-2012)
hal-00717212 , version 5 (09-01-2014)
hal-00717212 , version 6 (06-02-2015)
Nathan Krislock, Jérôme Malick, Frédéric Roupin. Computational results of a semidefinite branch-and-bound algorithm for k-cluster. Computers and Operations Research, 2016, 66, pp.153-159. ⟨10.1016/j.cor.2015.07.008⟩. ⟨hal-00717212v6⟩
861 Consultations
641 Téléchargements
