Fences in Weak Memory Models, LNCS, vol.6174, p.258272, 2010. ,
DOI : 10.1007/978-3-642-14295-6_25
URL : https://hal.archives-ouvertes.fr/hal-01100859
I-structures: Data structures for parallel computing, ACM Trans. on Programming Languages and Systems, vol.11, issue.4, p.598632, 1989. ,
DOI : 10.1007/3-540-18420-1_65
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.59.5638
Lucid, a nonprocedural language with iteration, Communications of the ACM, vol.20, issue.7, p.519526, 1977. ,
DOI : 10.1145/359636.359715
Analysis of Programs for Parallel Processing, IEEE Transactions on Electronic Computers, vol.15, issue.5, p.757762, 1966. ,
DOI : 10.1109/PGEC.1966.264565
Cyclo-static data flow, 1995 International Conference on Acoustics, Speech, and Signal Processing, p.32553258, 1995. ,
DOI : 10.1109/ICASSP.1995.479579
Real-Time Systems: Models and verication Theory and tools, chapter Synchronous Functional Programming with Lucid Synchrone, ISTE, 2007. ,
Synchronous Kahn networks, ICFP, p.226238, 1996. ,
DOI : 10.1145/232627.232651
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.15.9168
X10: an object-oriented approach to non-uniform cluster computing, OOPSLA, p.519538, 2005. ,
The architecture and system method of DDM1, Proceedings of the 5th annual symposium on Computer architecture , ISCA '78, p.210215, 1978. ,
DOI : 10.1145/800094.803050
A preliminary architecture for a basic data ow processor, ISCA, p.126132, 1974. ,
The implementation of the Cilk-5 multithreaded language, ACM Symp. on Programming Language Design and Implementation (PLDI), p.212223, 1998. ,
The Sisal model of functional programming and its implementation, Proceedings of IEEE International Symposium on Parallel Algorithms Architecture Synthesis, p.112, 1997. ,
DOI : 10.1109/AISPAS.1997.581640
Exploiting coarse-grained task, data, and pipeline parallelism in stream programs, ASPLOS, 2006. ,
The synchronous data ow programming language LUSTRE, Proceedings of the IEEE, p.13051320, 1991. ,
Axioms for concurrent objects, Proceedings of the 14th ACM SIGACT-SIGPLAN symposium on Principles of programming languages , POPL '87, p.1326, 1987. ,
DOI : 10.1145/41625.41627
Report on the programming language Haskell, ACM SIGPLAN Notices, vol.27, issue.5, p.1164134, 1992. ,
DOI : 10.1145/130697.130699
The semantics of a simple language for parallel programming, Information processing, p.471475, 1974. ,
Orchestrating the execution of stream programs on multicore platforms, PLDI, p.114124, 2008. ,
Static scheduling of synchronous data ow programs for digital signal processing, IEEE Trans. Computers, vol.36, issue.1, p.2425, 1987. ,
Eective communication and computation overlap with hybrid MPI/SMPSs, PPOPP, 2010. ,
Hierarchical Task-Based Programming With StarSs, International Journal of High Performance Computing Applications, vol.23, issue.3, p.284299, 2009. ,
DOI : 10.1177/1094342009106195
Leveraging Streaming for Deterministic Parallelization: an Integrated Language, Compiler and Runtime Approach, 2011. ,
URL : https://hal.archives-ouvertes.fr/pastel-00712006
A stream-computing extension to OpenMP, Proceedings of the 6th International Conference on High Performance and Embedded Architectures and Compilers, HiPEAC '11, p.514, 2011. ,
DOI : 10.1145/1944862.1944867
URL : https://hal.archives-ouvertes.fr/hal-00659411
Expressiveness and Data-Flow Compilation of OpenMP Streaming Programs, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00710409
Phasers, Proceedings of the 22nd annual international conference on Supercomputing , ICS '08, p.277288, 2008. ,
DOI : 10.1145/1375527.1375568
A survey of stream processing, Acta Informatica, vol.34, issue.7, p.491541, 1997. ,
DOI : 10.1007/s002360050095
A practical data ow computer, IEEE Computer, vol.15, issue.2, p.5157, 1982. ,
