PaperTonnetz: Music Composition with Interactive Paper - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Tonnetze are space-based musical representations that lay out individual pitches in a regular structure. They are primarily used for analysis with visualization tools or on paper and for performance with button-based tablet or tangible interfaces. This paper first investigates how properties of Tonnetze can be applied in the composition process, including the two-dimensional organization of pitches, based on a chord or on a scale. We then describe PaperTonnetz, a tool that lets musicians explore and compose music with Tonnetz representations by making gestures on interactive paper. Unlike screen-based interactive Tonnetz systems that treat the notes as playable buttons, PaperTonnetz allows composers to interact with gestures, creating replayable patterns that represent pitch sequences and/or chords. We describe the results of an initial test of the sys- tem in a public setting, and how we revised PaperTonnetz to better support three activities: discovering, improvising and assembling musical sequences in a Tonnetz. We con- clude with a discussion of directions for future research with respect to creating novel paper-based interactive music representations to support musical composition.
smc12.pdf (626.54 Ko) Télécharger le fichier
Format : Figure, Image
hal-00718334 , version 1 (16-07-2012)
  • HAL Id : hal-00718334 , version 1
Louis Bigo, Jérémie Garcia, Antoine Spicher, Wendy E. Mackay. PaperTonnetz: Music Composition with Interactive Paper. Sound and Music Computing, Jul 2012, Copenhague, Denmark. ⟨hal-00718334⟩
1060 Consultations
1656 Téléchargements
