Parallel algebraic domain decomposition solver for the solution of augmented systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Advances in Engineering Software Année : 2012
We consider the parallel iterative solution of indefinite linear systems given as augmented systems. Our numerical technique is based on an algebraic non overlapping domain decomposition technique that only exploits the graph of the sparse matrix. This approach to high-performance, scalable solution of large sparse linear systems in parallel scientific computing, is to combine direct and iterative methods. We report numerical and parallel performance of the scheme on large matrices arising from the finite element discretization of linear elasticity in structural mechanics problems.
hal-00719512 , version 1 (20-07-2012)
Emmanuel Agullo, Luc Giraud, Abdou Guermouche, Azzam Haidar, Jean Roman. Parallel algebraic domain decomposition solver for the solution of augmented systems. Advances in Engineering Software, 2012, 60-61, pp.23-30. ⟨10.1016/j.advengsoft.2012.07.004⟩. ⟨hal-00719512⟩
233 Consultations
0 Téléchargements
