Towards the parallelization of Reversible Jump Markov Chain Monte Carlo algorithms for vision problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
Point processes have demonstrated efficiency and competitiveness when addressing object recognition problems in vision. However, simulating these mathematical models is a difficult task, especially on large scenes. Existing samplers suffer from average performances in terms of computation time and stability. We propose a new sampling procedure based on a Monte Carlo formalism. Our algorithm exploits Markovian properties of point processes to perform the sampling in parallel. This procedure is embedded into a data-driven mechanism such that the points are non-uniformly distributed in the scene. The performances of the sampler are analyzed through a set of experiments on various object recognition problems from large scenes, and through comparisons to the existing algorithms.
RR-8016.pdf (2.99 Mo) Télécharger le fichier
hal-00720005 , version 1 (23-07-2012)
  • HAL Id : hal-00720005 , version 1
Yannick Verdie, Florent Lafarge. Towards the parallelization of Reversible Jump Markov Chain Monte Carlo algorithms for vision problems. [Research Report] RR-8016, INRIA. 2012. ⟨hal-00720005⟩
189 Consultations
111 Téléchargements
