System identification using quantized data, 2007 46th IEEE Conference on Decision and Control, 2007. ,
DOI : 10.1109/CDC.2007.4434350
A note on estimation using quantized data, Proc of the 17th IFAC World Congress, 2008. ,
DOI : 10.3182/20080706-5-KR-1001.02113
A Weighted Least-Squares Approach to Parameter Estimation Problems Based on Binary Measurements, IEEE Transactions on Automatic Control, vol.55, issue.1, pp.148-152, 2010. ,
DOI : 10.1109/TAC.2009.2033842
URL : https://hal.archives-ouvertes.fr/hal-00450295
On identification of FIR systems having quantized output data, Automatica, vol.47, issue.9, 1905. ,
DOI : 10.1016/j.automatica.2011.06.008
Statistical results for system identification based on quantized observations, Automatica, vol.45, issue.12, pp.2794-2801, 2009. ,
DOI : 10.1016/j.automatica.2009.09.014
Consistency of weighted least-square estimators for parameters estimation problems based on binary measurements. The 15th IFAC Symp. System Identification, 2009. ,
Estimation with quantized measurements, 1976 IEEE Conference on Decision and Control including the 15th Symposium on Adaptive Processes, 1976. ,
DOI : 10.1109/CDC.1976.267683
A robust SDP approach to system identification with roughly quantized data, 2009 IEEE International Conference on Systems, Man and Cybernetics, pp.2800-2805, 2009. ,
DOI : 10.1109/ICSMC.2009.5346585
A quadratic-programming-based method to quantized system identification, The 18th IFAC World Congress, pp.9052-9057, 2011. ,
A note on estimation with quantized data, IEEE Trans. Acoustics, Speech and Signal Processing, vol.33, issue.6, pp.1619-1621, 1985. ,
The reconstruction of analog signals from the sign of their noisy samples, IEEE Transactions on Information Theory, vol.27, issue.6, pp.735-745, 1981. ,
DOI : 10.1109/TIT.1981.1056424
Linear systems identification from random threshold binary data, IEEE Transactions on Signal Processing, vol.44, issue.8, pp.2064-2070, 1996. ,
DOI : 10.1109/78.533726
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.43.9849
Asymptotic property of optimal quantization for system identification, 2004. ,
CRITERIA FOR SYSTEM IDENTIFICATION WITH QUANTIZED DATA AND THE OPTIMAL QUANTIZATION SCHEMES, Proc of the 16th IFAC World Congress, 2005. ,
DOI : 10.3182/20050703-6-CZ-1902.00044
System identification using binary sensors, IEEE Transactions on Automatic Control, vol.48, issue.11, pp.1892-1906, 2003. ,
DOI : 10.1109/TAC.2003.819073
Joint identification of plant rational models and noise distribution functions using binary-valued observations, Automatica, vol.42, issue.4, pp.535-547, 2006. ,
DOI : 10.1016/j.automatica.2005.12.004
Asymptotically efficient parameter estimation using quantized output observations, Automatica, vol.43, issue.7, pp.1178-1191, 2007. ,
DOI : 10.1016/j.automatica.2006.12.030
Adaptive filtering using quantized output measurements, IEEE Transactions on Signal Processing, vol.46, issue.12, pp.3423-3426, 1998. ,
DOI : 10.1109/78.735317
