Rolling horizon procedures in Semi-Markov Games: The Discounted Case
Eugenio Della Vecchia 1 Silvia C. Di Marco 1 Alain Jean-Marie 2, 3
2 MAESTRO - Models for the performance analysis and the control of networks
CRISAM - Inria Sophia Antipolis - Méditerranée
3 LIRMM/HE - Hors Équipe
LIRMM - Laboratoire d'Informatique de Robotique et de Microélectronique de Montpellier
Abstract : We study the properties of the rolling horizon and the approximate rolling horizon procedures for the case of two-person zero-sum discounted semi-Markov games with infi nite horizon, under several assumptions on the reward function, when the state space is a borelian set and the action spaces are considered compact. Under suitable conditions, we prove that the equilibrium is the unique solution of its dynamic programming equation, and we prove bounds which imply the convergence of the procedures when the horizon length tends to in finity. The approach is based on the formalism for Semi-Markov games developed by Luque-Vásquez, together with extensions of the results of Hernández-Lerma and Lasserre for Markov Decision Processes and Chang and Marcus for Markov Games, both in discrete time. In this way we generalize the results on the rolling horizon and approximate rolling horizon procedures previously obtained for discrete-time problems.
Document type :
Reports
Complete list of metadatas
https://hal.inria.fr/hal-00720351
Contributor : Alain Jean-Marie <>
Submitted on : Wednesday, July 25, 2012 - 2:11:39 PM
Last modification on : Tuesday, November 13, 2018 - 2:38:01 AM
Long-term archiving on : Friday, October 26, 2012 - 2:20:36 AM
File
RR-8019.pdf
Identifiers
  • HAL Id : hal-00720351, version 1
Collections
Citation
Eugenio Della Vecchia, Silvia C. Di Marco, Alain Jean-Marie. Rolling horizon procedures in Semi-Markov Games: The Discounted Case. [Research Report] RR-8019, 2012. ⟨hal-00720351v1⟩
Share
Metrics
Record views
119
Files downloads
74
