Array placement for storage size reduction in embedded multimedia systems Application-Specific Systems, Architectures and Processors, IEEE International Conference on, p.66, 1997. ,
Shared memory implementations of synchronous dataflow specifications, Design, Automation and Test in Europe Conference and Exhibition 2000. Proceedings, pp.404-410, 2000. ,
Automatic storage optimization, 1979. ,
DOI : 10.1145/800229.806957
Optimisations mémoire dans la méthodologie aaa pour code embarqué sur architecturesparalì eles, 2006. ,
Dataflow process networks, Proceedings of the IEEE, pp.773-801, 1995. ,
DOI : 10.1109/5.381846
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.21.2539
Multi-core code generation from interface based hierarchy, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00440479
An Open Framework for Rapid Prototyping of Signal Processing Applications, EURASIP Journal on Embedded Systems, vol.75, issue.9, 2009. ,
DOI : 10.1109/78.295199
URL : https://hal.archives-ouvertes.fr/hal-00429312
A System-Level architecture model for rapid prototyping of heterogeneous multicore embedded systems, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00429397
Rapid prototyping and dataflow-based code generation for the 3gpp lte enodeb physical layer mapped onto multi-core dsps, 2010. ,
URL : https://hal.archives-ouvertes.fr/tel-00578043
Quasi-static scheduling for fine-grained embedded multiprocessing, 2009. ,
Synchronous data flow, Proceedings of the IEEE, vol.75, issue.9, pp.1235-1245, 1987. ,
DOI : 10.1109/PROC.1987.13876
Embedded Multiprocessors: Scheduling and Synchronization, 2009. ,
DOI : 10.1201/9781420048025
Memory efficient software synthesis with mixed coding style from dataflow graphs Very Large Scale Integration (VLSI) Systems, IEEE Transactions on, vol.8, issue.5, pp.522-526, 2000. ,
High-performance algorithms of compile-time scheduling of parallel processors, 1997. ,
About equivalent interval colorings of weighted graphs A new algorithm for the maximum-weight clique problem, Discrete Appl. Math. Nordic J. of Computing, vol.15716, issue.8, pp.3615-3624, 2001. ,
A new exact algorithm for the maximum weight clique problem, 23rd International Conference on Circuit/Systems, Computers and Communications (ITC-CSCC'08), 2008. ,
New efficient clique partitioning algorithms for register-transfer synthesis of data paths, Journal of the Korean Phys. Soc, vol.40, p.2002, 2002. ,
A constructive algorithm for memoryaware task assignment and scheduling, Proceedings of the ninth international symposium on Hardware/software codesign, ser. CODES '01, pp.147-152, 2001. ,
Automated memory-aware application distribution for Multi-processor System-on-Chips, Journal of Systems Architecture, vol.53, issue.11, pp.795-815, 2007. ,
DOI : 10.1016/j.sysarc.2007.01.013
Storage Estimation and Design Space Exploration Methodologies for the Memory Management of Signal Processing Applications, Journal of Signal Processing Systems, vol.2, issue.1, pp.51-71, 2008. ,
DOI : 10.1007/s11265-008-0244-0
