New interface
Reports (Research report)
A Case for Fully Decentralized Dynamic VM Consolidation in Clouds
Eugen Feller 1 Christine Morin 1 Armel Esnault 1
1 MYRIADS - Design and Implementation of Autonomous Distributed Systems
Inria Rennes – Bretagne Atlantique , IRISA-D1 - SYSTÈMES LARGE ÉCHELLE
Abstract : One way to conserve energy in cloud data centers is to transition idle servers into a power saving state during periods of low utilization. Dynamic virtual machine (VM) consolidation (VMC) algorithms are proposed to create idle times by periodically repacking VMs on the least number of physical machines (PMs). Existing works mostly apply VMC on top of centralized, hierarchical, or ring-based system topologies which result in poor scalability and/or packing efficiency with increasing number of PMs and VMs. In this paper we propose a novel fully decentralized dynamic VMC schema based on an unstructured peer-to-peer (P2P) network of PMs. The proposed schema is validated using three well known VMC algorithms: First-Fit Decreasing (FFD), Sercon, V-MAN, and a novel migration-cost aware ACO-based algorithm. Extensive experiments performed on the Grid'5000 testbed show that once integrated in our fully decentralized VMC schema, traditional VMC algorithms achieve a global packing efficiency very close to a centralized system. Moreover, the system remains scalable with increasing number of PMs and VMs. Finally, the migration-cost aware ACO-based algorithm outperforms FFD and Sercon in the number of released PMs and requires less migrations than FFD and V-MAN.
Document type :
Complete list of metadata
Cited literature [14 references]  Display  Hide  Download
https://hal.inria.fr/hal-00722245
Contributor : Eugen Feller Connect in order to contact the contributor
Submitted on : Tuesday, August 14, 2012 - 8:34:58 PM
Last modification on : Thursday, October 27, 2022 - 3:44:57 AM
Long-term archiving on: : Friday, December 16, 2016 - 6:37:40 AM
File
RR-8032.pdf
Identifiers
  • HAL Id : hal-00722245, version 2
Citation
Eugen Feller, Christine Morin, Armel Esnault. A Case for Fully Decentralized Dynamic VM Consolidation in Clouds. [Research Report] RR-8032, INRIA. 2012. ⟨hal-00722245v2⟩
Share
Metrics
Record views
470
Files downloads
869
