Explicit embeddings for nearest neighbor search with Mercer kernels - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Mathematical Imaging and Vision Année : 2015
Many approximate nearest neighbor search algorithms operate under memory constraints, by computing short signatures for database vectors while roughly keeping the neighborhoods for the distance of interest. Encoding procedures designed for the Euclidean distance have attracted much attention in the last decade.In the case where the distance of interest is based on a Mercer kernel, we propose a simple, yet effective two-step encoding scheme: first, compute an explicit embedding to map the initial space into a Euclidean space; second, apply an encoding step designed to work with the Euclidean distance. Comparing this simple baseline with existing methods relying on implicit encoding, we demonstrate better search recall for similar code sizes with the chi-square kernel in databases comprised of visual descriptors, outperforming concurrent state-of-the-art techniques by a large margin.
ee_ann_single.pdf (1.75 Mo) Télécharger le fichier
hal-00722635 , version 1 (02-08-2012)
hal-00722635 , version 2 (06-01-2015)
hal-00722635 , version 3 (28-01-2015)
hal-00722635 , version 4 (17-02-2015)
Anthony Bourrier, Florent Perronnin, Rémi Gribonval, Patrick Pérez, Hervé Jégou. Explicit embeddings for nearest neighbor search with Mercer kernels. Journal of Mathematical Imaging and Vision, 2015, 52 (3), pp.459-468. ⟨10.1007/s10851-015-0555-2⟩. ⟨hal-00722635v4⟩
836 Consultations
1316 Téléchargements
