Conference papers
Realtime Audio to Score Alignment for Polyphonic Music Instruments Using Sparse Non-negative constraints and Hierarchical HMMs
Arshia Cont 1
1 Musical Representations
STMS - Sciences et Technologies de la Musique et du Son
Abstract : We present a new method for realtime alignment of audio to score for polyphonic music signals. In this paper, we will be focusing mostly on the multiple-pitch observation algorithm proposed based on realtime Non-negative Matrix Factorization with sparseness constraints and hierarchical hidden Markov models for sequential modeling using particle filtering for decoding. The proposed algorithm has the advantage of having an explicit instrument model for pitch obtained through unsupervised learning as well as access to single note contribution probabilities which construct a complex chord instead of modeling the chord as one event.
Complete list of metadata
Cited literature [12 references]  Display  Hide  Download
https://hal.inria.fr/hal-00723224
Contributor : Arshia Cont Connect in order to contact the contributor
Submitted on : Wednesday, August 8, 2012 - 1:05:55 PM
Last modification on : Tuesday, March 15, 2022 - 3:19:45 AM
Long-term archiving on: : Friday, November 9, 2012 - 2:30:31 AM
File
arshiacont_icassp2006.pdf
Identifiers
  • HAL Id : hal-00723224, version 1
Citation
Arshia Cont. Realtime Audio to Score Alignment for Polyphonic Music Instruments Using Sparse Non-negative constraints and Hierarchical HMMs. IEEE International Conference in Acoustics and Speech Signal Processing (ICASSP), May 2006, Toulouse, France. ⟨hal-00723224⟩
Share
Metrics
Record views
95
Files downloads
539
