Affine and projective planes, Discrete Mathematics, vol.83, issue.2-3, pp.161-187, 1990. ,
DOI : 10.1016/0012-365X(90)90003-Z
Codes cycliques itendus affines-invariants et antichafnes d'un ensemble partiellement ordonn, Discrete Math, vol.5, issue.80, p.pp ,
DOI : 10.1016/0012-365x(90)90244-c
URL : http://doi.org/10.1016/0012-365x(90)90244-c
Distance Minimale et Enumhration des Poids des Codes Linkaires On the minimum distance of some BCH codes, Thbse de ,
Quelques resultats sur les codes BCH binaires en longueur 255, ENST stage rep., Annex, pp.229-247, 1982. ,
Shortened BCH codes (Corresp.), IEEE Transactions on Information Theory, vol.19, issue.6, pp.818-820, 1972. ,
DOI : 10.1109/TIT.1973.1055099
Some results on cyclic codes which are invariant under the affine group and their applications New generalisations of the Reed-Muller codes-Part I: Primitive codes, Inform. Contr. IEEE Trans. Inform. Theory, vol.11, issue.14, pp.475-496, 1967. ,
Some Remarks on BCH Bounds and Minimum Weights of Binary Primitive BCH Codes, IEEE Transactions on Information Theory, vol.15, issue.3, pp.408-413, 1961. ,
DOI : 10.1109/TIT.1969.1054304
On the minimum distance of cyclic codes, IEEE Transactions on Information Theory, vol.32, issue.1, pp.23-40, 1986. ,
DOI : 10.1109/TIT.1986.1057134
