High-Level Application Development for Sensor Networks: Data-Driven Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2011
Owing to the large scale of networked sensor systems, ease of program- ming remains a hurdle in their wide acceptance. High-level application development techniques, or macroprogramming provides an easy to use high-level representation to the application developer, who can focus on specifying the behavior of the system, as opposed to the constituent nodes of the wireless sensor network (WSN). This chapter provides an overview of the current approaches to high-level appli- cation design for WSNs, going into the details related to data-driven macroprogram- ming. Details of one such language are provided, in addition to the approach taken to the compilation of data-driven macroprograms to node-level code. An implemen- tation of the modular compilation framework is also discussed, as well as a graphical toolkit built around it that supports data-driven macroprogramming. Through exper- iments, it is shown that the code generated by the compiler matches hand-generated implementations of the applications, while drastically reducing the time and effort involved in developing real-world WSN applications.
pathak-prasanna-bookchapter.pdf (598.13 Ko) Télécharger le fichier
hal-00723799 , version 1 (10-12-2012)
Animesh Pathak, Viktor K. Prasanna. High-Level Application Development for Sensor Networks: Data-Driven Approach. Nikoletseas, Sotiris and Rolim, José D.P. Theoretical Aspects of Distributed Computing in Sensor Networks, Springer Berlin Heidelberg, pp.865-891, 2011, Monographs in Theoretical Computer Science. An EATCS Series, 978-3-642-14848-4. ⟨10.1007/978-3-642-14849-1_26⟩. ⟨hal-00723799⟩
Collections
INRIA INRIA2
117 Consultations
282 Téléchargements
