A new look at the statistical model identification, IEEE Trans. Autom. Control, vol.19, issue.6, pp.716-723, 1974. ,
An insight into instrumental variable frequency-domain subspace identification, Automatica, vol.46, issue.2, pp.375-382, 2010. ,
Output-only subspace-based structural identification: from theory to industrial testing practice, J. Dyn. Syst. Meas. Contr, vol.123, issue.4, pp.668-676, 2001. ,
In-flight monitoring of aeronautic structures: vibration-based on-line automated identification versus detection, IEEE Contr. Syst. Mag, vol.27, issue.5, pp.27-42, 2007. ,
Multivariable identification of a winding process by subspace methods for tension control, Control Eng. Pract, vol.6, issue.9, pp.1077-1088, 1998. ,
Order estimation for subspace methods, Automatica, vol.37, issue.10, pp.1561-1573, 2001. ,
Asymptotic properties of subspace estimators, Automatica, vol.41, issue.3, pp.359-376, 2005. ,
Consistency and asymptotic normality of some subspace algorithms for systems without observed inputs, Automatica, vol.35, issue.7, pp.1243-1254, 1999. ,
Some facts about the choice of the weighting matrices in Larimore type of subspace algorithms, Automatica, vol.38, issue.5, pp.763-773, 2002. ,
Single sample modal identification of a nonstationary stochastic process, IEEE Trans. Autom. Control AC, vol.30, issue.1, pp.66-74, 1985. ,
Non-stationary consistency of subspace methods, IEEE Trans. Autom. Control AC, vol.52, issue.6, pp.974-984, 2007. ,
Ambient vibration re-testing and operational modal analysis of the Humber Bridge, Eng. Struct, vol.32, issue.8, pp.2003-2018, 2010. ,
Testing the rank of the Hankel covariance matrix: A statistical approach, IEEE Trans. Autom. Control, vol.46, issue.2, pp.331-336, 2001. ,
Vibration based condition monitoring: a review, Struct. Health Monit, vol.3, issue.4, pp.355-377, 2004. ,
On the relation between CCA and predictor-based subspace identification, IEEE Trans. Autom. Control, vol.52, issue.10, pp.1795-1812, 2007. ,
Asymptotic variance of subspace methods by data orthogonalization and model decoupling: a comparative analysis, Automatica, vol.40, issue.10, pp.1705-1717, 2004. ,
Fast subspace-based system identification: An instrumental variable approach, Automatica, vol.31, issue.6, pp.903-905, 1995. ,
Consistency and relative efficiency of subspace methods, Automatica, vol.31, issue.12, pp.1865-1875, 1995. ,
Fast multi-order stochastic subspace identification, Proc. 18th IFAC World Congress, 2011. ,
Modular subspace-based system identification from multi-setup measurements, IEEE Trans. Autom. Control, 2011. ,
System identification from ambient vibration measurements on a bridge, J. Sound Vib, vol.205, issue.1, pp.1-18, 1997. ,
Matrix computations, 1996. ,
Modal testing and analysis of structures under operational conditions: industrial application, Mech. Syst. Signal Pr, vol.13, issue.2, pp.193-216, 1999. ,
The natural excitation technique (NExT) for modal parameter extraction from operating structures, Modal Analysis, vol.10, pp.260-277, 1995. ,
Eigensystem realization algorithm for modal parameter identification and model reduction, J. Guid. Control Dynam, vol.8, issue.5, pp.620-627, 1985. ,
Identification of the Tennessee Eastman challenge process with subspace methods, Control Eng. Pract, vol.9, issue.12, pp.1337-1351, 2001. ,
A new identification and model reduction algorithm via singular value decomposition, Proc. 12th Asilomar Conf. Circuits, Systems, and Computers, pp.705-714, 1978. ,
Recursive subspace identification of linear and non-linear Wiener state-space models, Automatica, vol.36, issue.11, pp.1639-1650, 2000. ,
Description of Z24 benchmark, Mech. Syst. Signal Pr, vol.17, issue.1, pp.127-131, 2003. ,
Application of structured total least squares for system identification and model reduction, IEEE Trans. Autom. Control, vol.50, issue.10, pp.1490-1500, 2005. ,
A fast algorithm for subspace state-space system identification via exploitation of the displacement structure, J. Comput. Appl. Math, vol.132, issue.1, pp.71-81, 2001. ,
The structured total least squares problem, Contemp. Math, vol.280, issue.12, pp.157-176, 2001. ,
Propagator-based methods for recursive subspace model identification, Signal Process, vol.88, issue.3, pp.468-491, 2008. ,
Stochastic subspace-based structural identification and damage detection -application to the steel-quake benchmark, Mech. Syst. Signal Pr, vol.17, issue.1, pp.91-101, 2003. ,
Input/output versus output-only data processing for structural identification -application to in-flight data analysis, J. Sound Vib, vol.295, issue.3, pp.531-552, 2006. ,
Recursive 4SID algorithms using gradient type subspace tracking, Automatica, vol.38, issue.6, pp.1035-1043, 2002. ,
Modified subspace identification for long-range prediction model for inferential control, Control Eng. Pract, vol.16, issue.12, pp.1487-1500, 2008. ,
Application of frequency-domain system identification techniques in the field of operational modal analysis, 2003. ,
System identification and damage detection in civil engineering, 2000. ,
Reference-based stochastic subspace identification for output-only modal analysis, Mech. Syst. Signal Pr, vol.13, issue.6, pp.855-878, 1999. ,
Stochastic system identification for operational modal analysis: a review, J. Dyn. Syst. Meas. Contr, vol.123, issue.4, pp.659-667, 2001. ,
State-space formulation, a solution to modal parameter estimation, J. Sound Vib, vol.148, issue.2, pp.329-342, 1991. ,
Parallel QR implementation of subspace identification with parsimonious models, Proc. 13th IFAC SYSID Symp, pp.1631-1636, 2003. ,
Reference-based combined deterministicstochastic subspace identification for experimental and operational modal analysis, Mech. Syst. Signal Pr, vol.22, issue.3, pp.617-637, 2008. ,
Automated interpretation of stability diagrams, Proc. 29th Int. Modal Anal. Conf, 2011. ,
Modeling by shortest data description, Automatica, vol.14, issue.5, pp.465-471, 1978. ,
Stabilisation diagrams: Pole identification using fuzzy clustering techniques, Adv. Eng. Softw, vol.36, pp.768-779, 2005. ,
System identification of suspension bridge from ambient vibration response, Eng. Struct, vol.30, issue.2, pp.462-477, 2008. ,
Multivariable identification of an activated sludge process with subspace-based algorithms, Control Eng. Pract, vol.11, issue.8, pp.961-969, 2003. ,
Introduction to spectral analysis, 1997. ,
An optimized parallel fft algorithm on multiprocessors with cache technology in linux, Int. Symp. Computer Science and Computational Technology, pp.105-109, 2008. ,
Discriminating physical poles from mathematical poles in high order systems: use and automation of the stabilization diagram, Proc. 21st IEEE Instr. Meas. Techn. Conf, pp.2193-2198, 2004. ,
Closed-loop MOESP subspace model identification with parametrisable disturbances, Proc. 49th IEEE Conf. Decision Control. IEEE, pp.2813-2818, 2010. ,
Subspace Identification for Linear Systems: Theory, Implementation, 1996. ,
FEM updating of tall buildings using ambient vibration data, Proc. 6th Int. Conf. Struct. Dyn. (EURODYN), 2005. ,
Subspace-based methods for the identification of linear timeinvariant systems, Automatica, vol.31, issue.12, pp.1835-1851, 1995. ,
11 3 Accumulated computation times for multi-order SSI system identification up to different model orders n * with maximal model order n max = 500. 11 4 Computation times for multi-order ERA system identification of system matrices A j and C j , n j = j = 1, . . . , n max from O n max at different maximal model orders n max with r = 251, r 0 = 5, c ? 50 ,
