New interface
Conference papers
Bridging the Gap between RIF and SPARQL: Implementation of a RIF Dialect with a SPARQL Rule Engine
Oumy Seye 1 Catherine Faron Zucker 1 Olivier Corby 1 Corentin Follenfant 1, 2
1 WIMMICS - Web-Instrumented Man-Machine Interactions, Communities and Semantics
CRISAM - Inria Sophia Antipolis - Méditerranée , Laboratoire I3S - SPARKS - Scalable and Pervasive softwARe and Knowledge Systems
Abstract : Semantic Web knowledge representation standards have close relationships with rule-based languages and systems. In particular, the sparql query language can be seen as a rule language: answering a construct query is similar to applying a rule in forward chaining to enrich an rdf base, with the rule antecedent corresponding to the where clause and its consequent to the construct clause of the sparql query. In this paper we present the correspondances between sparql and rif, the rule interchange format recommended by the W3C. We have characterized the subset of sparql that can be expressed in rif and, conversely, we have searched for the maximal rif dialect that can be expressed in sparql. We have extended the Corese semantic engine which enables to query rdf/s data with sparql and is provided with both a forward and a backward chaining rule system, so that it now supports rif: we have developed (1) a rif parser which builds an internal representation of a rif rule into an abstract syntax tree (AST) and (2) a translator of a rif AST into a sparql AST so that Corese has become an implementation of a rif-sparql dialect.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00724291
Contributor : Oumy Seye Connect in order to contact the contributor
Submitted on : Monday, August 20, 2012 - 2:24:46 PM
Last modification on : Friday, August 5, 2022 - 3:50:25 AM
Identifiers
  • HAL Id : hal-00724291, version 1
Citation
Oumy Seye, Catherine Faron Zucker, Olivier Corby, Corentin Follenfant. Bridging the Gap between RIF and SPARQL: Implementation of a RIF Dialect with a SPARQL Rule Engine. Artificial Intelligence meets the Web of Data workshop, ECAI, Aug 2012, montpellier, France. ⟨hal-00724291⟩
Share
Metrics
Record views
257
