Leveraging business workflows in distributed systems research for the orchestration of reproducible and scalable experiments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
Tomasz Buchert
  • Fonction : Auteur
  • PersonId : 871843
Lucas Nussbaum
While rapid research on distributed systems is observed, experiments in this field are often difficult to design, describe, conduct and reproduce. By overcoming these difficulties the research could be further stimulated and add more credibility to results in distributed systems research. The key factors responsible for this situation are technical (software bugs and hardware errors), methodological (incorrect practices), as well as social (reluctance to share work). In this paper, the existing approaches for the management of experiments on distributed systems are described and a novel approach using business process management (BPM) is presented to address their shortcomings. Then, the questions arising when such approach is taken, are addressed. We show that it can be a better alternative to the traditional way of performing experiments as it encourages better scientific practices and results in more valuable research and publications. Finally, a plan of our future work is outlined and other applications of this work are discussed.
Malgré une activité de recherche sur les systèmes distribués très importante et très active, les expériences dans ce domaine sont souvent difficiles à concevoir, décrire, mener et reproduire. Surmonter ces difficultés pourrait permettre à ce domaine d'être encore plus stimulé, et aux résultats de gagner en crédibilité, à la fois dans le domaine des systèmes distribués. Les facteurs principaux responsables de cette situation sont techniques (bugs logiciels, problèmes matériels), méthodologiques (mauvaises pratiques), et sociaux (réticence à partager son travail). Dans cet article, les approches existantes pour la description et la conduite d'expériences sur les systèmes distribués sont décrites, et une nouvelle approche, utilisant le \textsl{Business Process Management (BPM)}, est présentée pour répondre à leurs limitations. Puis diverses questions se posant lors de l'utilisation d'une telle approche sont discutées. Nous montrons que cette approche peut être une meilleure alternative à la manière traditionnelle de conduire des expériences, qui encourage de meilleures pratiques scientifiques, et qui résulte en une recherche et des publications de meilleure qualité. Pour finir, notre plan de travail est décrit, et des applications possibles de ce travail dans d'autres domaines sont décrites.
RR-8048.pdf (594.14 Ko) Télécharger le fichier
hal-00724313 , version 1 (20-08-2012)
hal-00724313 , version 2 (27-08-2012)
hal-00724313 , version 3 (26-11-2012)
  • HAL Id : hal-00724313 , version 2
Tomasz Buchert, Lucas Nussbaum. Leveraging business workflows in distributed systems research for the orchestration of reproducible and scalable experiments. [Research Report] RR-8048, 2012. ⟨hal-00724313v2⟩
Collections
INRIA-RRRT
347 Consultations
524 Téléchargements
