SBV regularity for Hamilton-Jacobi equations with Hamiltonian depending on (t,x) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Mathematical Analysis Année : 2012
In this paper we prove the SBV regularity of the gradient of a viscosity solution of the Hamilton-Jacobi equation under the hypothesis of uniform convexity of the Hamiltonian H(t,x,D_xu) in the last variable. This result extends the result of Bianchini, De Lellis and Robyr obtained for a Hamiltonian H(D_x u) which depends only on the spatial gradient of the solution.
Tonon-Bianchini.pdf (261.93 Ko) Télécharger le fichier
hal-00918462 , version 1 (17-12-2013)
Stefano Bianchini, Daniela Tonon. SBV regularity for Hamilton-Jacobi equations with Hamiltonian depending on (t,x). SIAM Journal on Mathematical Analysis, 2012, 44 (3), pp.2179-2203. ⟨10.1137/110827272⟩. ⟨hal-00918462⟩
299 Consultations
250 Téléchargements
