Smoothing Technique of Nonsmooth Newton Methods for Control-State Constrained Optimal Control Problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Numerical Analysis Année : 2012
Jinhai Chen
  • Fonction : Auteur
This paper is concerned with the numerical solution of optimal control problems subject to mixed control-state constraints with differential-algebraic equations. The necessary conditions arising from a local minimum principle are transformed into an equivalent nonsmooth equation in appropriate Banach spaces. We then develop a parametric smoothing Newton method for solving this nonsmooth equation. The global and local convergence is proposed under suitable settings. Numerical examples are presented to demonstrate the efficiency of our global smoothing technique.
Fichier non déposé
hal-00724868 , version 1 (22-08-2012)
Jinhai Chen, Matthias Gerdts. Smoothing Technique of Nonsmooth Newton Methods for Control-State Constrained Optimal Control Problems. SIAM Journal on Numerical Analysis, 2012, 50 (4), pp.1982-2011. ⟨10.1137/110822177⟩. ⟨hal-00724868⟩
108 Consultations
1 Téléchargements
