Post-Optimal Sensitivities of Flight Trajectories with Respect to Selected Parameters
In the paper at hand, the sensitivities of optimized flight trajectories with respect to selected parameters are to be investigated. Especially atmospheric influences like wind or deviations from the standard atmosphere shall be regarded since those parameters strongly influence the respective optimal trajectory.
