High-Resolution Depth Maps Based on TOF-Stereo Fusion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The combination of range sensors with color cameras can be very useful for robot navigation, semantic perception, manipulation, and telepresence. Several methods of combining range- and color-data have been investigated and successfully used in various robotic applications. Most of these systems suffer from the problems of noise in the range-data and resolution mismatch between the range sensor and the color cameras, since the resolution of current range sensors is much less than the resolution of color cameras. High-resolution depth maps can be obtained using stereo matching, but this often fails to construct accurate depth maps of weakly/repetitively textured scenes, or if the scene exhibits complex self-occlusions. Range sensors provide coarse depth information regardless of presence/absence of texture. The use of a calibrated system, composed of a time-of-flight (TOF) camera and of a stereoscopic camera pair, allows data fusion thus overcoming the weaknesses of both individual sensors. We propose a novel TOF-stereo fusion method based on an efficient seed-growing algorithm which uses the TOF data projected onto the stereo image pair as an initial set of correspondences. These initial ''seeds'' are then propagated based on a Bayesian model which combines an image similarity score with rough depth priors computed from the low-resolution range data. The overall result is a dense and accurate depth map at the resolution of the color cameras at hand. We show that the proposed algorithm outperforms 2D image-based stereo algorithms and that the results are of higher resolution than off-the-shelf color-range sensors, e.g., Kinect. Moreover, the algorithm potentially exhibits real-time performance on a single CPU.
GhandiCechHoraud_ICRA12.pdf (617.31 Ko) Télécharger le fichier
Format : Figure, Image
hal-00725616 , version 1 (27-08-2012)
Vineet Gandhi, Jan Cech, Radu Horaud. High-Resolution Depth Maps Based on TOF-Stereo Fusion. ICRA 2012 - IEEE International Conference on Robotics and Automation, IEEE Robotics and Automation Society, May 2012, Saint-Paul, Minnesota, United States. pp.4742-4749, ⟨10.1109/ICRA.2012.6224771⟩. ⟨hal-00725616⟩
438 Consultations
1276 Téléchargements
