TLA+ Proofs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
TLA+ Proofs
TLA+ is a specification language based on standard set theory and temporal logic that has constructs for hierarchical proofs. We describe how to write TLA+ proofs and check them with TLAPS, the \tlaplus Proof System. We use Peterson's mutual exclusion algorithm as a simple example and show how TLAPS and the Toolbox (an IDE for TLA+) help users to manage large, complex proofs.
final.pdf (285.16 Ko) Télécharger le fichier
hal-00726631 , version 1 (27-03-2013)
Denis Cousineau, Damien Doligez, Leslie Lamport, Stephan Merz, Daniel Ricketts, et al.. TLA+ Proofs. 18th International Symposium On Formal Methods - FM 2012, Aug 2012, Paris, France. pp.147-154, ⟨10.1007/978-3-642-32759-9_14⟩. ⟨hal-00726631⟩
520 Consultations
573 Téléchargements
