The design and use of steerable filters, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.13, issue.9, pp.891-906, 1991. ,
DOI : 10.1109/34.93808
A parametric texture model based on joint statistics of complex wavelet coefficients, International Journal of Computer Vision, vol.40, issue.1, pp.49-71, 2000. ,
DOI : 10.1023/A:1026553619983
Wavelet-based texture retrieval using generalized Gaussian density and Kullback-Leibler distance, IEEE Transactions on Image Processing, vol.11, issue.2, pp.146-158, 2002. ,
DOI : 10.1109/83.982822
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.1.2426
Texture Similarity Measure Using Kullback-Leibler Divergence between Gamma Distributions, Proceedings of the 7th European Conference on Computer Vision, pp.133-147, 2002. ,
DOI : 10.1007/3-540-47977-5_9
A New Wavelet-Based Texture Descriptor for Image Retrieval, Computer Analysis of Images and Patterns, 2007. ,
DOI : 10.1007/978-3-540-74272-2_111
Multivariate statistical modeling of images with the curvelet transform, Proceedings of the Eighth International Symposium on Signal Processing and Its Applications, 2005., pp.747-750, 2005. ,
DOI : 10.1109/ISSPA.2005.1581046
URL : https://hal.archives-ouvertes.fr/hal-01088628
Multivariate statistical approach for image denoising, IEEE ICASSP, vol.4, pp.589-592, 2005. ,
Change Detection in Multisensor SAR Images Using Bivariate Gamma Distributions, IEEE Transactions on Image Processing, vol.17, issue.3, pp.249-258, 2008. ,
DOI : 10.1109/TIP.2008.916047
URL : https://hal.archives-ouvertes.fr/hal-00467504
Rotation-invariant texture retrieval with gaussianized steerable pyramids, IEEE Transactions on Image Processing, vol.15, issue.9, pp.2702-2718, 2006. ,
DOI : 10.1109/TIP.2006.877356
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.108.6100
Texture characterization via joint statistics of wavelet coefficient magnitudes, Proceedings 1998 International Conference on Image Processing. ICIP98 (Cat. No.98CB36269), pp.4-7, 1998. ,
DOI : 10.1109/ICIP.1998.723417
Fonctions de répartition à n dimensions et leurs marges, pp.229-231, 1959. ,
Multivariate models and dependence concepts ,
An Introduction to Copulas' Lecture Notes in Statistics, 1998. ,
