Statistical texture characterization from discrete wavelet representations, IEEE Transactions on Image Processing, vol.8, issue.4, pp.592-598, 1999. ,
DOI : 10.1109/83.753747
A Parametric Texture Model Based on Joint Statistics of Complex Wavelet Coefficients, International Journal of Computer Vision, vol.40, issue.1, pp.49-70, 2000. ,
DOI : 10.1023/A:1026553619983
Wavelet-based texture retrieval using generalized Gaussian density and Kullback-Leibler distance, IEEE Transactions on Image Processing, vol.11, issue.2, pp.146-158, 2002. ,
DOI : 10.1109/83.982822
Image similarity measurement by Kullback-Leibler divergences between complex wavelet subband statistics for texture retrieval, 2008 15th IEEE International Conference on Image Processing, pp.933-936, 2008. ,
DOI : 10.1109/ICIP.2008.4711909
The asymmetric generalized Gaussian function: a new HOS-based model for generic noise pdfs, Proceedings of 8th Workshop on Statistical Signal and Array Processing, pp.210-213, 1996. ,
DOI : 10.1109/SSAP.1996.534855
HOS-based generalized noise pdf models for signal detection optimization, Signal Processing, vol.65, issue.2, pp.267-281, 1998. ,
DOI : 10.1016/S0165-1684(97)00223-5
Maximum likelihood parameter estimation of the asymmetric generalised Gaussian family of distributions, Proceedings of the IEEE Signal Processing Workshop on Higher-Order Statistics. SPW-HOS '99, pp.255-258, 1999. ,
DOI : 10.1109/HOST.1999.778737
Complex Wavelets for Shift Invariant Analysis and Filtering of Signals, Complex Wavelets for Shift Invariant Analysis and Filtering of Signals Applied and Computational Harmonic Analysis International Conference on, pp.234-253, 1970. ,
DOI : 10.1006/acha.2000.0343
