Optimization of advanced well type and performance, 9th European Conference on the Mathematics of Oil Recovery (ECMOR IX) ,
Dynamic control of genetic algorithms in a noisy environment, Proceedings of the Fifth International Conference on Genetic Algorithms, pp.48-55, 1993. ,
Scheduling of Genetic Algorithms in a Noisy Environment, Evolutionary Computation, vol.5, issue.2, pp.97-122, 1994. ,
DOI : 10.1109/69.166988
Optimizing smart well controls under geologic uncertainty, Journal of Petroleum Science and Engineering, vol.73, issue.1-2, pp.107-121, 2010. ,
DOI : 10.1016/j.petrol.2010.05.012
Efficiency and Mutation Strength Adaptation of the (??/?? I, ??)-ES in a Noisy Environment, Parallel Problem Solving from Nature PPSN VI, pp.39-48, 1917. ,
DOI : 10.1007/3-540-45356-3_4
Local Performance of the (??/??I, ??)-ES in a Noisy Environment, Foundations of Genetic Algorithms, vol.6, pp.127-141, 2001. ,
DOI : 10.1016/B978-155860734-7/50090-1
Optimization of nonconventional wells under uncertainty using statistical proxies, Computational Geosciences, vol.10, issue.4, pp.389-404, 2006. ,
DOI : 10.1007/s10596-006-9031-9
Field Development Planning Using Simulated Annealing - Optimal Economic Well Scheduling and Placement, SPE Annual Technical Conference and Exhibition, 1995. ,
DOI : 10.2118/30650-MS
??)-Theory, Evolutionary Computation, vol.15, issue.2, pp.165-188, 1993. ,
DOI : 10.1162/evco.1993.1.2.165
Partially Separated Meta-models with Evolution Strategies for Well Placement Optimization, SPE EUROPEC/EAGE Annual Conference and Exhibition, p.2012 ,
DOI : 10.2118/143292-MS
URL : https://hal.archives-ouvertes.fr/hal-00588983
Well placement optimization with the covariance matrix adaptation evolution strategy and meta-models, Computational Geosciences, vol.13, issue.4, pp.75-92, 2011. ,
DOI : 10.1007/s10596-011-9254-2
URL : https://hal.archives-ouvertes.fr/hal-00628126
Creating robust solutions by means of evolutionary algorithms, Proceedings of the 5th International Conference on Parallel Problem Solving from Nature, PPSN V, pp.119-128, 1998. ,
DOI : 10.1007/BFb0056855
Faster convergence by means of fitness estimation, Soft Computing, vol.9, issue.1, pp.13-20, 2005. ,
DOI : 10.1007/s00500-003-0329-4
Efficient fitness estimation in noisy environments, Proceedings of Genetic and Evolutionary Computation, pp.243-250, 2001. ,
Ensemble-based closed-loop production optimization, 2008. ,
DOI : 10.2118/112873-ms
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.158.1491
Ensemble-based closed-loop optimization applied to Brugge field, SPE reservoir simulation symposium, number SPE 118926, 2009. ,
DOI : 10.2118/118926-pa
Efficient Ensemble-Based Closed-Loop Production Optimization, SPE Journal, vol.14, issue.04, pp.634-645, 2009. ,
DOI : 10.2118/112873-PA
Sequential data assimilation with a nonlinear quasi-geostrophic model using Monte Carlo methods to forecast error statistics, Journal of Geophysical Research, vol.109, issue.Part 4, pp.10143-10162, 1994. ,
DOI : 10.1029/94JC00572
Genetic algorithms in noisy environments, Machine Learning, pp.101-120, 1988. ,
DOI : 10.1007/BF00113893
Methods for quantifying the uncertainty of production forecasts: a comparative study, Petroleum Geoscience, vol.7, issue.S, pp.87-96, 2001. ,
DOI : 10.1144/petgeo.7.S.S87
A Two-Stage Well Placement Optimization Method Based on Adjoint Gradient, SPE Annual Technical Conference and Exhibition, p.135304, 2010. ,
DOI : 10.2118/135304-MS
An Iterative Ensemble Kalman Filter for Multiphase Fluid Flow Data Assimilation, SPE Journal, vol.12, issue.04, pp.438-446, 2007. ,
DOI : 10.2118/108438-PA
Optimization of Well Placement, Journal of Energy Resources Technology, vol.122, issue.2, pp.64-70, 2000. ,
DOI : 10.1115/1.483164
Uncertainty assessment of well placement optimization, SPE annual technical conference and exhibition, number SPE, 2001. ,
Optimization of well placement in a gulf of mexico waterflooding project, SPE annual technical conference and exhibition, number SPE 63221, 2000. ,
Adjoint-based wellplacement optimization under production constraints, SPE reservoir simulation symposium, p.105797, 2007. ,
A Method for Handling Uncertainty in Evolutionary Optimization With an Application to Feedback Control of Combustion, IEEE Transactions on Evolutionary Computation, vol.13, issue.1, pp.180-197, 2009. ,
DOI : 10.1109/TEVC.2008.924423
URL : https://hal.archives-ouvertes.fr/inria-00276216
Completely Derandomized Self-Adaptation in Evolution Strategies, Evolutionary Computation, vol.9, issue.2, pp.159-195, 2001. ,
DOI : 10.1016/0004-3702(95)00124-7
Hoeffding and Bernstein races for selecting policies in evolutionary direct policy search, Proceedings of the 26th Annual International Conference on Machine Learning, ICML '09, pp.401-408, 2009. ,
DOI : 10.1145/1553374.1553426
Evolutionary Optimization in Uncertain Environments???A Survey, IEEE Transactions on Evolutionary Computation, vol.9, issue.3, pp.303-317, 2005. ,
DOI : 10.1109/TEVC.2005.846356
Automatic Determination of Well Placement Subject to Geostatistical and Economic Constraints, SPE International Thermal Operations and Heavy Oil Symposium and International Horizontal Well Technology Conference, p.78996, 2002. ,
DOI : 10.2118/78996-MS
Application of a particle swarm optimization algorithm for determining optimum well location and type, Computational Geosciences, vol.13, issue.4, pp.183-198, 2010. ,
DOI : 10.1007/s10596-009-9142-1
Optimization of Well Placement Under Time-Dependent Uncertainty, SPE Reservoir Evaluation & Engineering, vol.9, issue.02, pp.135-145, 2006. ,
DOI : 10.2118/90091-PA
Efficient search for robust solutions by means of evolutionary algorithms and fitness approximation, IEEE Transactions on Evolutionary Computation, vol.10, issue.4, pp.405-420, 2006. ,
DOI : 10.1109/TEVC.2005.859465
Optimization of Noisy Fitness Functions by Means of Genetic Algorithms Using History of Search, Parallel Problem Solving from Nature PPSN VI, pp.571-580, 1917. ,
DOI : 10.1007/3-540-45356-3_56
Optimization of noisy fitness functions by means of genetic algorithms using history of search with test of estimation, Proceedings of the 2002 Congress on Evolutionary Computation. CEC'02 (Cat. No.02TH8600), pp.360-365, 1917. ,
DOI : 10.1109/CEC.2002.1006261
Efficient Well Placement Optimization with Gradient-based Algorithms and Adjoint Models, Intelligent Energy Conference and Exhibition, 2008. ,
DOI : 10.2118/112257-MS
Multiple-Objective Optimization Applied to Well Path Design under Geological Uncertainty, SPE Reservoir Simulation Symposium, p.141712, 2011. ,
DOI : 10.2118/141712-MS
Well path design optimization under geological uncertainty: Application to a complex north sea field, SPE Russian Oil and Gas Conference and Exhibition, number SPE 136288, 2010. ,
Averaging efficiently in the presence of noise, Parallel Problem Solving from Nature -PPSN V, volume 1498 of Lecture Notes in Computer Science, pp.188-197 ,
DOI : 10.1007/BFb0056862
Optimal Well Placement Under Uncertainty Using a Retrospective Optimization Framework, SPE Journal, vol.17, issue.01, pp.112-121, 2012. ,
DOI : 10.2118/141950-PA
Optimization of Nonconventional Well Type, Location, and Trajectory, SPE Journal, vol.8, issue.03, pp.200-210, 2003. ,
DOI : 10.2118/86880-PA
