Optimal Balancing of Road Traffic Density Distributions for the Cell Transmission Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Dominik Pisarski
  • Fonction : Auteur
  • PersonId : 924452
In this paper, we study the problem of optimal balancing of traffic density distributions. The optimization is carried out over the sets of equilibrium points for the Cell Transmission Traffic Model. The goal is to find the optimal balanced density distribution that maximizes the Total Travel Distance. The optimization is executed in two steps. At the first step, we consider a nonlinear problem to find a uniform density distribution that maximizes the Total Travel Distance. The second step is to solve the constrained quadratic problem to find the near balanced optimal equilibrium point. At both steps, we use decomposition methods. The quadratic optimization problem is solved by using the Dual Problem. The computational algorithms associated to such a problem are given.
CDC_2012_04_09.pdf (115.33 Ko) Télécharger le fichier
hal-00727783 , version 1 (04-09-2012)
  • HAL Id : hal-00727783 , version 1
Dominik Pisarski, Carlos Canudas de Wit. Optimal Balancing of Road Traffic Density Distributions for the Cell Transmission Model. CDC 2012 - 51st IEEE Conference on Decision and Control, Dec 2012, Maui, Hawaii, United States. ⟨hal-00727783⟩
396 Consultations
416 Téléchargements
