Correlation-Based Burstiness for Logo Retrieval - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Detecting logos in photos is challenging. A reason is that logos locally resemble patterns frequently seen in random images. We propose to learn a statistical model for the distribution of incorrect detections output by an image matching algorithm. It results in a novel scoring criterion in which the weight of correlated keypoint matches is reduced, penalizing irrelevant logo detections. In experiments on two very diff erent logo retrieval benchmarks, our approach largely improves over the standard matching criterion as well as other state-of-the-art approaches.
msp073-revaud.pdf (1.11 Mo) Télécharger le fichier
Format : Figure, Image
hal-00728502 , version 1 (06-09-2012)
Jérôme Revaud, Matthijs Douze, Cordelia Schmid. Correlation-Based Burstiness for Logo Retrieval. MM 2012 - ACM International Conference on Multimedia, Oct 2012, Nara, Japan. pp.965-968, ⟨10.1145/2393347.2396358⟩. ⟨hal-00728502⟩
561 Consultations
1297 Téléchargements
