New interface
Conference papers
A modular memory optimization for synchronous data-flow languages: application to arrays in a lustre compiler
Léonard Gérard 1 Adrien Guatto 1 Cédric Pasteur 1 Marc Pouzet 1
1 Parkas - Parallélisme de Kahn Synchrone
DI-ENS - Département d'informatique - ENS Paris, Inria Paris-Rocquencourt, CNRS - Centre National de la Recherche Scientifique : UMR 8548
Abstract : The generation of efficient sequential code for synchronous data-flow languages raises two intertwined issues: control and memory optimization. While the former has been extensively studied, for instance in the compilation of Lustre and Signal, the latter has only been addressed in a restricted manner. Yet, memory optimization becomes a pressing issue when arrays are added to such languages. This article presents a two-level solution to the memory optimization problem. It combines a compile-time optimization algorithm, reminiscent of register allocation, paired with language annotations on the source given by the designer. Annotations express in-place modifications and control where allocation is performed. Moreover, they allow external functions performing in-place modifications to be safely imported. Soundness of annotations is guaranteed by a semilinear type system and additional scheduling constraints. A key feature is that annotations for well-typed programs do not change the semantics of the language: removing them may lead to less efficient code but will not alter the semantics. The method has been implemented in a new compiler for a LUSTRE-like synchronous language extended with hierarchical automata and arrays. Experiments show that the proposed approach removes most of the unnecessary array copies, resulting in faster code that uses less memory.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00728527
Contributor : Cédric Pasteur Connect in order to contact the contributor
Submitted on : Thursday, September 6, 2012 - 12:04:53 PM
Last modification on : Thursday, March 17, 2022 - 10:08:43 AM
Identifiers
Collections
Citation
Léonard Gérard, Adrien Guatto, Cédric Pasteur, Marc Pouzet. A modular memory optimization for synchronous data-flow languages: application to arrays in a lustre compiler. Proceedings of the 13th ACM SIGPLAN/SIGBED International Conference on Languages, Compilers, Tools and Theory for Embedded Systems, Jun 2012, Beijing, China. pp.51--60, ⟨10.1145/2248418.2248426⟩. ⟨hal-00728527⟩
Share
Metrics
Record views
220
