Dynamic Bayesian networks for symbolic polyphonic pitch modeling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2012
Symbolic pitch modeling is a way of incorporating knowledge about relations between pitches into the process of analyzing musical information or signals, and it is typically done in a statistical framework. It has proven to be an efficient way of improving the performance of various Music Information Retrieval (MIR) algorithms. In this paper, we propose a family of probabilistic symbolic polyphonic pitch models for multiple pitch estimation, which account for both the ''horizontal'' and the ''vertical'' pitch structure. These models are formulated as linear or log-linear interpolations of up to five submodels, each of which is responsible for modeling a different aspect of music. The ability of the models to predict symbolic pitch data is evaluated in terms of their cross-entropy, and of a newly proposed ''contextual cross-entropy'' measure. Their performance is then measured on synthesized polyphonic audio signals in terms of the accuracy of multiple pitch estimation in combination with a Nonnegative Matrix Factorization-based acoustic model. In both experiments, the log-linear combinations of at least one ''horizontal'' (e.g.\ harmony) and one ''vertical'' (e.g.\ note duration) models outperformed the baseline methods, by almost 60\% in cross-entropy reduction and almost 4\% in multiple pitch estimation accuracy. This work provides a proof of concept of the usefulness of model interpolation in the area of pitch modeling, which may be used for improved symbolic modeling in the future.
RT-430.pdf (1006.05 Ko) Télécharger le fichier
hal-00728771 , version 1 (06-09-2012)
hal-00728771 , version 2 (26-10-2012)
hal-00728771 , version 3 (25-03-2013)
  • HAL Id : hal-00728771 , version 2
Stanislaw Raczynski, Emmanuel Vincent, Shigeki Sagayama. Dynamic Bayesian networks for symbolic polyphonic pitch modeling. [Technical Report] RT-0430, 2012. ⟨hal-00728771v2⟩
Collections
INRIA-RRRT
274 Consultations
316 Téléchargements
