Abstract : We present LFR (Loop Free Routing), a new loop-free distance vector routing algorithm, which is able to update the shortest paths of a distributed network with n nodes in fully dynamic scenarios. If Phi is the total number of nodes affected by a set of updates to the network, and phi is the maximum number of destinations for which a node is affected, then LFR requires O(Phi*Delta) messages and O(n + phi*Delta) space per node, where Delta is the maximum degree of the nodes of the network. We experimentally compare LFR with DUAL, one of the most popular loop-free distance vector algorithms, which is part of CISCO's EIGRP protocol and requires O(Phi*Delta) messages and Θ(n*Delta) space per node. The experiments are based on both real-world and artificial instances and show that LFR is always the best choice in terms of memory require- ments, while in terms of messages LFR outperforms DUAL on real-world instances, whereas DUAL is the best choice on artificial instances.
