Node Coloring in Wireless Networks: Complexity Results and Grid Coloring - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ichrak Amdouni
  • Fonction : Auteur
  • PersonId : 898418
Pascale Minet
Cédric Adjih
Coloring is used in wireless networks to improve communication efficiency, mainly in terms of bandwidth, energy and possibly end-to-end delays. In this paper, we define the h-hop node coloring problem, with h any positive integer, adapted to two types of applications in wireless networks. We specify both general mode for general applications and strategic mode for data gathering applications.We prove that the associated decision problem is NP-complete. We then focus on grid topologies that constitute regular topologies for large or dense wireless networks. We consider various transmission ranges and identify a color pattern that can be reproduced to color the whole grid with the optimal number of colors. We obtain an optimal periodic coloring of the grid for the considered transmission range. We then present a 3-hop distributed coloring algorithm, called SERENA. Through simulation results, we highlight the impact of node priority assignment on the number of colors obtained for any network and grids in particular. We then compare these optimal results on grids with those obtained by SERENA and identify directions to improve SERENA.
WMNC11AmdouniI.pdf (419.97 Ko) Télécharger le fichier
hal-00729051 , version 1 (07-09-2012)
Ichrak Amdouni, Pascale Minet, Cédric Adjih. Node Coloring in Wireless Networks: Complexity Results and Grid Coloring. WMNC 2011 - 4th Joint IFIP Wireless and Mobile Networking Conference, Oct 2011, Toulouse, France. ⟨10.1109/WMNC.2011.6097255⟩. ⟨hal-00729051⟩
169 Consultations
135 Téléchargements
