Hybrid metaheuristic for multi-objective biclustering in microarray data - Archive ouverte HAL Access content directly
Conference Papers Year : 2012
Biclustering is a well-known data mining problem in the field of gene expression data. It consists in extracting genes that behave similarly under some experimental conditions. As the Biclustering problem is NP-Complete in most of its variants, many heuristics and metaheuristics are defined to solve for it. Classical algorithms allow the extraction of some biclusters in reasonable time, however most of them remain time consuming. In this work, we propose a new hybrid multi-objective meta-heuristic H-MOBI based on NSGA-II (Non-dominated Sorting Genetic Algorithm II), CC (Cheng and Church) heuristic and a multi-objective local search PLS-1 (Pareto Local Search 1). Experimental results on real data sets show that our approach can find significant biclusters of high quality.
Not file
Dates and versions
hal-00732459 , version 1 (14-09-2012)
Identifiers
Cite
Khedidja Seridi, Laetitia Jourdan, El-Ghazali Talbi. Hybrid metaheuristic for multi-objective biclustering in microarray data. CIBCB 2012 - IEEE Symposium on Computational Intelligence in Bioinformatics and Computational Biology, May 2012, San Diego, United States. pp.222-228, ⟨10.1109/CIBCB.2012.6217234⟩. ⟨hal-00732459⟩
90 View
0 Download
Share
