Analysing routing protocols: four nodes topologies are sufficient - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Routing protocols aim at establishing a route between nodes on a network. Secured versions of routing protocols have been proposed in order to provide more guarantees on the resulting routes. Formal methods have proved their usefulness when analysing standard security protocols such as confidentiality or authentication protocols. However, existing results and tools do not apply to routing protocols. This is due in particular to the fact that all possible topologies (infinitely many) have to be considered. \par In this paper, we propose a simple reduction result: when looking for attacks on properties such as the validity of the route, it is sufficient to consider topologies with only four nodes, resulting in a number of just five distinct topologies to consider. As an application, we analyse the SRP applied to DSR and the SDMSR protocols using the ProVerif tool.
hal-00732911 , version 1 (17-09-2012)
Véronique Cortier, Jan Degrieck, Stéphanie Delaune. Analysing routing protocols: four nodes topologies are sufficient. 1st International Conference on Principles of Security and Trust (POST'12), Mar 2012, Tallinn, Estonia. pp.30--50, ⟨10.1007/978-3-642-28641-4_3⟩. ⟨hal-00732911⟩
408 Consultations
0 Téléchargements
