An algebraic approach for human posture estimation in the sagittal plane using accelerometer noisy signal - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Our aim is to develop an algebraic approach to estimate human posture in the sagittal plane using Inertial Measurement Unit (IMU) providing accelerations and angular velocities. To do it so, we address the issue of the estimation of the amplitude, frequency and phase of a biased and noisy sum of three sinusoidal waveform signals on a moving time horizon. Since the length of the time window is small, the estimation must be done within a fraction of the signal's period. The problem is solved via algebraic techniques (see [38] for the theoretical part concerning this problem). The efficiency of our approach is illustrated by computer simulations.
Automatique
final-version-cdc-paper-PBMUF.pdf (461.38 Ko) Télécharger le fichier
hal-00733516 , version 1 (18-09-2012)
Wilfrid Perruquetti, Mamadou Mboup, Rosane Ushirobira, Philippe Fraisse, Vincent Bonnet. An algebraic approach for human posture estimation in the sagittal plane using accelerometer noisy signal. CDC: Conference on Decision and Control, Dec 2012, Maui, HI, United States. pp.7389-7394, ⟨10.1109/CDC.2012.6426001⟩. ⟨hal-00733516⟩
578 Consultations
364 Téléchargements
