An??lise do padr??o eletromiogr??fico durante os agachamentos padr??o e declinado, Brazilian Journal of Physical Therapy, vol.13, issue.2, pp.164-172, 2009. ,
DOI : 10.1590/S1413-35552009005000021
URL : http://doi.org/10.1590/s1413-35552009005000021
Muscle Strength and Flexibility Characteristics of People Displaying Excessive Medial Knee Displacement, Archives of Physical Medicine and Rehabilitation, vol.89, issue.7, pp.1323-1328, 2008. ,
DOI : 10.1016/j.apmr.2007.11.048
On the parametrization and design of an extended Kalman filter frequency tracker, IEEE Transactions on Automatic Control, vol.45, issue.9, pp.1718-1724, 2000. ,
DOI : 10.1109/9.880631
Mazzà and A. Cappozzo Trunk orientation estimate during walking using gyroscope sensors, IEEE Int. Conf. on Biomedical Robotics and Biomechatronics, 2012. ,
A least-squares identification algorithm for estimating squat exercise mechanics using a single inertial measurement unit, Journal of Biomechanics, vol.45, issue.8, 2012. ,
DOI : 10.1016/j.jbiomech.2012.02.014
URL : https://hal.archives-ouvertes.fr/lirmm-00800165
Minimum measured-input models for the assessment of motor ability, Journal of Biomechanics, vol.35, issue.4, pp.437-446, 2002. ,
DOI : 10.1016/S0021-9290(01)00186-5
An optimized Kalman filter for the estimate of trunk orientation from inertial sensors data during treadmill walking, gait and posture, pp.138-142, 2002. ,
Adaptive motor strategy for squatting in spastic diplegia, European Journal of Paediatric Neurology, vol.3, issue.4, pp.159-165, 1999. ,
DOI : 10.1016/S1090-3798(99)90049-1
Knee biomechanics of the dynamic squat exercise, Medicine and Science in Sports and Exercise, vol.10, pp.1556-1565, 2009. ,
DOI : 10.1097/00005768-200101000-00020
Analyse non standard du bruit, Comptes Rendus Mathematique, vol.342, issue.10, pp.797-802, 2006. ,
DOI : 10.1016/j.crma.2006.02.037
URL : https://hal.archives-ouvertes.fr/inria-00001134
Critique du rapport signaì a bruit en communications numériques, pp.419-429, 2008. ,
Algebraic change-point detection, Applicable Algebra Engin, Communic. Comput, vol.21, pp.131-143, 2010. ,
DOI : 10.1007/s00200-010-0119-z
URL : http://arxiv.org/abs/0912.1178
Questioning some paradigms of signal processing via concrete examples, Algebraic Methods in Flatness, Signal Processing and State Estimation, Editorial Lagares, pp.1-21, 2003. ,
URL : https://hal.archives-ouvertes.fr/inria-00001059
An algebraic framework for linear identification, ESAIM: Control, Optimisation and Calculus of Variations, vol.9, pp.151-168, 2003. ,
DOI : 10.1051/cocv:2003008
Closed-loop Parametric Identification for Continuous-time Linear Systems via New Algebraic Techniques ,
DOI : 10.1007/978-1-84800-161-9_13
URL : https://hal.archives-ouvertes.fr/inria-00114958
Non-linear estimation is easy, International Journal of Modelling, Identification and Control, vol.4, issue.1, pp.12-27, 2008. ,
DOI : 10.1504/IJMIC.2008.020996
URL : https://hal.archives-ouvertes.fr/inria-00158855
Effect of knee position on hip and knee torques during the barbell squat, Journal of Strength and Conditioning Research, vol.17, pp.629-633, 2003. ,
The Use of Wearable Inertial Motion Sensors in Human Lower Limb Biomechanics Studies: A Systematic Review, Sensors, vol.10, issue.12, pp.1556-1565, 2009. ,
DOI : 10.3390/s101211556
Adaptive Filter Theory, 1991. ,
A globally convergent frequency estimator, IEEE Transactions on Automatic Control, vol.44, issue.4, pp.698-713, 1999. ,
DOI : 10.1109/9.754808
On the consistency of Prony's method and related algorithms, J. Comput. Graph. Statist, vol.1, pp.329-349, 1992. ,
Accelerometer and rate gyroscope measurement of kinematics: an inexpensive alternative to optical motion analysis systems, Journal of Biomechanics, vol.35, issue.4, pp.537-542, 2002. ,
DOI : 10.1016/S0021-9290(01)00231-7
A revised look at numerical differentiation with an application to nonlinear feedback control, 2007 Mediterranean Conference on Control & Automation, 2007. ,
DOI : 10.1109/MED.2007.4433728
URL : https://hal.archives-ouvertes.fr/inria-00142588
Parameter estimation for signals described by differential equations, Applicable Analysis, vol.26, issue.1, pp.29-52, 2009. ,
DOI : 10.1109/MED.2008.4602161
Numerical differentiation with annihilators in noisy environment, Numerical Algorithms, vol.14, issue.12, pp.439-467, 2009. ,
DOI : 10.1007/s11075-008-9236-1
URL : https://hal.archives-ouvertes.fr/inria-00319240
An Adaptive Notch Filter for Frequency Estimation of a Periodic Signal, IEEE Transactions on Automatic Control, vol.49, issue.2, pp.314-318, 2004. ,
DOI : 10.1109/TAC.2003.821414
An Algebraic Receiver for Full Response CPM Demodulation, VI Int, Telecom. Symp. (ITS2006), 2006. ,
A Modified Prony Algorithm for Exponential Function Fitting, SIAM Journal on Scientific Computing, vol.16, issue.1, pp.119-138, 1995. ,
DOI : 10.1137/0916008
Adaptive IIR Filtering in Signal Processing and Control, Marcel Dekker, 1995. ,
Essai expérimental et analytique : sur les lois de la dilatabilité de fluidesélastiquesfluides´fluidesélastiques et sur celles de la force expansive de la vapeur de l'eau et de la vapeur de l'alcooì a différentes températures, Journal de l'´ ecole polytechnique, pp.24-76 ,
Adaptive cancelling of physiological tremor for improved precision in microsurgery, IEEE Transactions on Biomedical Engineering, vol.45, issue.7, pp.839-846, 1998. ,
DOI : 10.1109/10.686791
ESPRIT-estimation of signal parameters via rotational invariance techniques, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.37, issue.7, pp.984-995, 1989. ,
DOI : 10.1109/29.32276
An algebraic frequency estimator for a biased and noisy sinusoidal signal, Signal Processing, vol.87, issue.6, pp.1188-1201, 2007. ,
DOI : 10.1016/j.sigpro.2006.10.006
A fast on-line frequency estimator of lightly damped vibrations in flexible structures, Journal of Sound and Vibration, vol.307, issue.1-2, pp.365-378, 2007. ,
DOI : 10.1016/j.jsv.2007.07.005
On-line frequency and damping estimation in a single-link flexible manipulator based on algebraic identification, 2008. ,
On the algebraic identification of the frequencies, amplitudes and phases of two sinusoidal signals from their noisy sum, International Journal of Control, vol.339, issue.3, pp.507-518, 2008. ,
DOI : 10.1016/j.sigpro.2004.05.008
Estimation algébrique des paramètres intrinsèques d'un signal sinuso¨?dalsinuso¨?dal biaisé en environnement bruité, Proc. Gretsi, 5-9 septembre, 2011. ,
