Compatibilization of Immiscible Polymer Blends by Organoclay: Effect of Nanofiller or Organo-Modifier? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Macromolecular Materials and Engineering Année : 2013
PET/PE blends are prepared with and without different types of organo-modified montmorillonites (OMMT) using a extrusion process. The droplet size of PE dispersed phase decreases upon organoclays addition, however without any direct dependence on the organoclay initial surface tension. To assess the effect of the organomodifier without MMT, PET/PE blends are then compounded adding solely the surfactants (similar to those used to modify the various organoclays). Whatever the chemical nature of the surfactant, a refinement of the PE droplets is observed, interestingly similar to those previously observed in presence of clay. This shows unambiguously that the key factor for organoclay compatibilization efficiency, in the case of PET/PE blends, is the surfactant modifier itself and not the nanofiller.
Matériaux
hal-00734557 , version 1 (23-09-2012)
Mohamed Yousfi, Jeremie Soulestin, Bruno Vergnes, Marie-France Lacrampe, Patricia Krawczak. Compatibilization of Immiscible Polymer Blends by Organoclay: Effect of Nanofiller or Organo-Modifier?. Macromolecular Materials and Engineering, 2013, 298 (7), pp.757-770. ⟨10.1002/mame.201200138⟩. ⟨hal-00734557⟩
170 Consultations
0 Téléchargements
