The filtering step of discrete logarithm and integer factorization algorithms
Cyril Bouvier 1
1 CARAMEL - Cryptology, Arithmetic: Hardware and Software
Inria Nancy - Grand Est, LORIA - ALGO - Department of Algorithms, Computation, Image and Geometry
Abstract : The security of most current public-key cryptosystems is based on the difficulty of finding discrete logarithms in large finite fields or factoring large integers. Most discrete logarithm and integer factoring algorithms, such as the Number Field Sieve (NFS) or the Function Field Sieve (FFS), can be described in 3 main steps: data collection, filtering and linear algebra. The goal of the filtering step is to generate a small, sparse matrix over a finite field, for which one will compute the kernel during the linear algebra step. The filtering step is mainly a structured Gaussian elimination (SGE). For the current factorization records, billions of data are collected in the first step and have to be processed in the filtering step. One part of the filtering step is to remove heavy rows of the matrix. The choice of the weight function to select heavy rows is critical in order to obtain the smallest matrix possible. In this paper, several weight functions are studied in order to determine which one is more suited in the context of discrete logarithm and factorization algorithms.
Type de document :
Pré-publication, Document de travail
2013
Liste complète des métadonnées
Littérature citée [18 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/hal-00734654
Contributeur : Cyril Bouvier <>
Soumis le : lundi 3 juin 2013 - 12:44:18
Dernière modification le : mardi 18 décembre 2018 - 16:18:25
Document(s) archivé(s) le : mardi 4 avril 2017 - 15:30:17
Fichier
article.pdf
Fichiers produits par l'(les) auteur(s)
  • HAL Id : hal-00734654, version 3
Collections
Citation
Cyril Bouvier. The filtering step of discrete logarithm and integer factorization algorithms. 2013. 〈hal-00734654v3〉
Métriques
Consultations de la notice
896
Téléchargements de fichiers
573
