Accelerating Iterative SpMV for Discrete Logarithm Problem using GPUs
In the context of cryptanalysis, computing discrete logarithms in large cyclic groups using index-calculus-based methods, such as the number field sieve or the function field sieve, requires solving large sparse systems of linear equations modulo the group order. Most of the fast algorithms used to solve such systems --- e.g., the conjugate gradient or the Lanczos and Wiedemann algorithms --- iterate a product of the corresponding sparse matrix with a vector (SpMV). This central operation can be accelerated on GPUs using specific computing models and addressing patterns, which increase the arithmetic intensity while reducing irregular memory accesses. In this work, we investigate the implementation of SpMV kernels on NVIDIA GPUs, for several representations of the sparse matrix in memory. We explore the use of Residue Number System (RNS) arithmetic to accelerate modular operations. We target linear systems arising when attacking the discrete logarithm problem on groups of size 160 to 320 bits, which are relevant for current cryptanalytic computations. The proposed SpMV implementation contributed to solving the discrete logarithm problem in GF($2^{619}$) and GF($2^{809}$) using the FFS algorithm.
