Semi-automatic annotation process for procedural texts: An application on cooking recipes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Taaable is a case-based reasoning system that adapts cooking recipes to user constraints. Within it, the preparation part of recipes is formalised as a graph. This graph is a semantic representation of the sequence of instructions composing the cooking process and is used to compute the procedure adaptation, conjointly with the textual adaptation. It is composed of cooking actions and ingredients, among others, represented as vertices, and semantic relations between those, shown as arcs, and is built automatically thanks to natural language processing. The results of the automatic annotation process is often a disconnected graph, representing an incomplete annotation, or may contain errors. Therefore, a validating and correcting step is required. In this paper, we present an existing graphic tool named \kcatos, conceived for representing and editing decision trees, and show how it has been adapted and integrated in WikiTaaable, the semantic wiki in which the knowledge used by Taaable is stored. This interface provides the wiki users with a way to correct the case representation of the cooking process, improving at the same time the quality of the knowledge about cooking procedures stored in WikiTaaable.
CCC_2012.pdf (2 Mo) Télécharger le fichier
hal-00735262 , version 1 (25-09-2012)
Valmi Dufour-Lussier, Florence Le Ber, Jean Lieber, Thomas Meilender, Emmanuel Nauer. Semi-automatic annotation process for procedural texts: An application on cooking recipes. Cooking with Computers workshop - ECAI 2012, Aug 2012, Montpellier, France. ⟨hal-00735262⟩
235 Consultations
113 Téléchargements
