New interface
Reports (Research report)
Resolvability of Visual-Inertial Structure from Motion in Closed-form
Agostino Martinelli 1
1 E-MOTION - Geometry and Probability for Motion and Action
Inria Grenoble - Rhône-Alpes, LIG - Laboratoire d'Informatique de Grenoble
Abstract : This paper investigates the visual-inertial structure from motion problem. A simple closed form solution to this problem is introduced. Special attention is devoted to identify the conditions under which the problem has a finite number of solutions. Specifically, it is shown that the problem can have a unique solution, two distinct solutions and infinite solutions depending on the trajectory, on the number of point-features and on their layout and on the number of camera images. The investigation is also performed in the case when the inertial data are biased, showing that, in this latter case, more images and more restrictive conditions on the trajectory are required for the problem resolvability.
Complete list of metadata
Cited literature [19 references]  Display  Hide  Download
https://hal.inria.fr/hal-00735826
Contributor : Agostino Martinelli Connect in order to contact the contributor
Submitted on : Sunday, March 24, 2013 - 3:02:02 PM
Last modification on : Wednesday, October 26, 2022 - 8:16:32 AM
Long-term archiving on: : Sunday, April 2, 2017 - 7:42:15 PM
File
RR-8076.pdf
Identifiers
  • HAL Id : hal-00735826, version 2
Citation
Agostino Martinelli. Resolvability of Visual-Inertial Structure from Motion in Closed-form. [Research Report] RR-8076, INRIA. 2012. ⟨hal-00735826v2⟩
Share
Metrics
Record views
171
Files downloads
181
