Low-density parity-check codes, IEEE Transactions on Information Theory, vol.8, issue.1, pp.21-28, 1962. ,
DOI : 10.1109/TIT.1962.1057683
Near Shannon limit performance of low density parity check codes, Electronics Letters, vol.33, issue.6, pp.457-458, 1997. ,
DOI : 10.1049/el:19970362
A recursive approach to low complexity codes, IEEE Transactions on Information Theory, vol.27, issue.5, pp.533-547, 1981. ,
DOI : 10.1109/TIT.1981.1056404
Generalized low density (Tanner) codes, 1999 IEEE International Conference on Communications (Cat. No. 99CH36311), pp.441-445, 1999. ,
DOI : 10.1109/ICC.1999.767979
On generalized low-density parity-check codes based on Hamming component codes, IEEE Communications Letters, vol.3, issue.8, pp.248-250, 1999. ,
DOI : 10.1109/4234.781010
Generalized Low-Density Parity-Check Codes Based on Hadamard Constraints, IEEE Transactions on Information Theory, vol.53, issue.3, pp.1058-1079, 2007. ,
DOI : 10.1109/TIT.2006.890694
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.96.6891
A hybrid coding scheme for the Gilbert-Elliott channel, IEEE Transactions on Communications, vol.54, issue.10, pp.1787-1796, 2006. ,
DOI : 10.1109/TCOMM.2006.881365
Generalized LDPC codes with Reed-Solomon and BCH codes as component codes for binary channels, GLOBECOM '05. IEEE Global Telecommunications Conference, 2005., pp.1239-1244, 2005. ,
DOI : 10.1109/GLOCOM.2005.1577850
Generalized low-density parity-check codes for optical communication systems, Journal of Lightwave Technology, vol.23, issue.5, pp.1939-1946, 2005. ,
DOI : 10.1109/JLT.2005.846892
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.473.7400
Doubly Generalized LDPC Codes, 2006 IEEE International Symposium on Information Theory, pp.669-673, 2006. ,
DOI : 10.1109/ISIT.2006.261869
URL : https://hal.archives-ouvertes.fr/hal-00865899
Analysis of Doubly- Generalized LDPC Codes with Random Component Codes for the Binary Erasure Channel, Proceedings of Allerton Conference on Communications, Control and Computing, 2006. ,
Lowrate coding using incremental redundancy for GLDPC codes, IEEE International Workshop on Satellite and Space Communications, pp.299-303, 2008. ,
DOI : 10.1109/iwssc.2008.4656817
URL : https://hal.archives-ouvertes.fr/inria-00305684
Low density parity check (ldpc) staircase and triangle forward error correction (fec) schemes, IETF Request for Comments, RFC, vol.5170, 2008. ,
DOI : 10.17487/rfc5170
URL : https://hal.archives-ouvertes.fr/inria-00000147
Complexity comparison of the use of Vandermonde versus Hankel matrices to build systematic MDS Reed-Solomon codes, 2012 IEEE 13th International Workshop on Signal Processing Advances in Wireless Communications (SPAWC), 2012. ,
DOI : 10.1109/SPAWC.2012.6292924
URL : https://hal.archives-ouvertes.fr/hal-00719314
On Generator Matrices of MDS Codes, IT-31, pp.826-830, 1985. ,
Optimization with exit functions of GLDPC-Staircase codes for the BEC, 2012 IEEE 13th International Workshop on Signal Processing Advances in Wireless Communications (SPAWC), 2012. ,
DOI : 10.1109/SPAWC.2012.6292979
URL : https://hal.archives-ouvertes.fr/hal-00719321
