The function field sieve, ANTS I, pp.108-121, 1994. ,
Function field sieve method for discrete logarithms over finite fields, Inf. Comput, vol.151, issue.12, pp.5-16, 1999. ,
Using C ab curves in the function field sieve, IEICE Trans. Fund, issue.3, pp.551-552, 1999. ,
Estimates for discrete logarithm computations in finite fields of small characteristic, Cryptography and Coding, pp.190-206, 2003. ,
Function field sieve in characteristic three, ANTS VI, pp.223-234, 2004. ,
Computation of discrete logarithms in F 2 607, ASIACRYPT 2001, pp.107-124 ,
Fast evaluation of logarithms in fields of characteristic two, IEEE Trans. Inf. Theory, vol.30, issue.4, pp.587-594, 1984. ,
Solving a 676-bit discrete logarithm problem in GF (3 6n ), PKC 2010, pp.351-367 ,
Breaking pairing-based cryptosystems using ?T pairing over GF (3 97 ), ASIACRYPT 2012, pp.43-60 ,
A kilobit special number field sieve factorization, ASIACRYPT 2007, pp.1-12 ,
CADO-NFS: Crible algébrique: Distribution, optimisation ? Number field sieve ,
Discrete logarithms and local units, Phil. Trans. R. Soc. A, vol.345, pp.409-423, 1676. ,
Massively parallel computation of discrete logarithms, CRYPTO '92, pp.312-323 ,
Applications of fast truncated multiplication in cryptography, EURASIP J. Embed. Syst, p.61721, 2007. ,
The lattice sieve The development of the number field sieve, pp.43-49, 1993. ,
Sieving using bucket sort, ASI- ACRYPT 2004, pp.92-102 ,
NTL: A library for doing number theory ,
ZEN: A toolbox for fast computation in finite extension over finite rings ,
gf2x: A library for multiplying polynomials over the binary field ,
The function field sieve in the medium prime case, EUROCRYPT 2006, pp.254-270 ,
URL : https://hal.archives-ouvertes.fr/hal-00456191
Faster implementation of ?T pairing over GF(3 m ) using minimum number of logical instructions for GF(3)-addition, Pairing 2008, pp.282-296 ,
