Planning as heuristic search : New results, Proc. 5th European Conf. on Planning, pp.359-371, 1999. ,
Planning as heuristic search, Artificial Intelligence, vol.129, issue.12, pp.5-33, 2001. ,
Goal transformations in continuous planning, Proceedings of the AAAI Fall Symposium on Distributed Continual Planning, 1998. ,
STRIPS : A new approach to the application of theorem proving to problem solving, Artificial Intelligence, issue.2, pp.3-4, 1971. ,
Plan stability : Replanning versus plan repair, Proc. ICAPS, pp.212-221, 2006. ,
A formal basis for the heuristic determination of minimum cost paths, IEEE Transactions on Systems, Man and Cybernetics, vol.2, pp.100-107, 1968. ,
The FF Planning System : Fast Plan Generation Through Heuristic Search, Journal of Artificial Intelligence Research, vol.14, issue.1, pp.253-302, 2001. ,
Moving target search, Proceedings of the International Joint Conference on Artificial Intelligence, pp.204-210, 1991. ,
A realtime search for changing goals, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.6, issue.17, pp.609-619, 1995. ,
A validation-structure-based theory of plan modification and reuse, Artif. Intell, vol.55, pp.193-258, 1992. ,
D* lite, Proceedings of the Association for the Advancement of Artificial Intelligence, pp.476-483, 2002. ,
Adaptive A*, Proceedings of the International Conference on Autonomous Agent and Muti-Agent Systems, pp.1311-1312, 2005. ,
Speeding up moving target search, Proceedings of the International Conference on Autonomous Agent and Muti-Agent Systems, 2007. ,
Plan reuse versus plan generation : A theoretical and empirical analysis, Artificial Intelligence, vol.76, pp.427-454, 1995. ,
Generalized adaptive A*, Proceedings of the International Conference on Autonomous Agents and Multiagent Systems, pp.469-476, 2008. ,
Efficient incremental search for moving target search, Proceedings of the International Joint Conference on Artificial Intelligence, pp.615-620, 2009. ,
Generalized Fringe-Retrieving A* : Faster Moving Target Search on State Lattices, Proceedings of the Internation Joint Conference on Autonous Agents and MultiAgent Systems, pp.1081-1088, 2010. ,
Moving target D* lite, Proceedings of the International Conference on Autonomous Agents and Multi-agent Systems, pp.67-74, 2010. ,
Plan repair as an extension of planning, Proceedings of the International Conference on Planning and Scheduling (ICAPS-05), pp.161-170, 2005. ,
