Journal articles
An Approach to Database Preference Queries Based on an Outranking Relation
Abstract : In this paper, we describe an approach to database preference queries based on the notion of outranking, suited to the situation where preferences on different attributes are not commensurable. This model constitutes an alternative to the use of Pareto order whose main drawback is to leave many tuples incomparable in general. Even though outranking does not define an order in the mathematical sense of the term, we describe a technique which yields a complete pre-order, based on a global aggregation of the outranking degrees computed for each pair of tuples, which reflects the global "quality" of a tuple w.r.t. the others.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-00736336
Contributor : Olivier Pivert Connect in order to contact the contributor
Submitted on : Friday, September 28, 2012 - 9:39:02 AM
Last modification on : Monday, March 21, 2022 - 2:24:59 PM
Links full text
Identifiers
Citation
Patrick Bosc, Olivier Pivert, Grégory Smits. An Approach to Database Preference Queries Based on an Outranking Relation. International Journal of Computational Intelligence Systems, Atlantis Press, 2012, 5 (4), pp.789-804. ⟨10.1080/18756891.2012.718161⟩. ⟨hal-00736336⟩
Share
Metrics
Record views
92
