A Database and Evaluation Methodology for Optical Flow, International Journal of Computer Vision, vol.27, issue.3, pp.1-31, 2010. ,
DOI : 10.1007/s11263-010-0390-2
Performance of optical flow techniques, International Journal of Computer Vision, vol.54, issue.1, pp.43-77, 1994. ,
DOI : 10.1007/BF01420984
Cardiac Motion Estimation Using Covariant Derivatives and Helmholtz Decomposition, MICCAI workshop LNCS 7085, pp.263-273 ,
DOI : 10.1007/978-3-642-28326-0_27
How to calculate dense piv vector fields at video rate, 8th Int. Symp. On Particle Image Velocimetry -PIV09, 2009. ,
Pressure image asimilation for atmospheric motion estimation, pp.160-178, 2009. ,
Fluid experimental flow estimation based on an optical-flow scheme, Experiments in Fluids, vol.10, issue.5, pp.80-97, 2006. ,
DOI : 10.1007/s00348-005-0048-y
URL : https://hal.archives-ouvertes.fr/halshs-00008138
A variational approach to cardiac motion estimation based on covariant derivatives and multi-scale Helmholtz decomposition, Quarterly of Applied Mathematics, vol.71, issue.1, 2012. ,
DOI : 10.1090/S0033-569X-2012-01313-0
A Fourier???Wavelet Monte Carlo Method for Fractal Random Fields, Journal of Computational Physics, vol.132, issue.2, pp.384-408, 1997. ,
DOI : 10.1006/jcph.1996.5647
Sequential data assimilation with a non linear quasi-geostrophic model using Monte Carlo methods to forecast error statistics, J. Geophys. Res, vol.99, issue.C510, pp.143-162, 1994. ,
The Ensemble Kalman Filter: theoretical formulation and practical implementation, Ocean Dynamics, vol.53, issue.4, pp.343-367, 2003. ,
DOI : 10.1007/s10236-003-0036-9
The intrinsic structure of optic flow incorporating measurement duality, International Journal of Computer Vision, vol.27, issue.3, pp.263-286, 1998. ,
DOI : 10.1023/A:1007922215235
Recovering motion fields: an analysis of eight optical flow algorithms, Proc. British Mach. Vis. Conf, 1998. ,
Novel approach to non-linear/non-Gaussian Bayesian state estimation, IEEE Processing-F, vol.140, issue.2, 1993. ,
Bayesian selection of scaling laws for motion modeling in images, 2009 IEEE 12th International Conference on Computer Vision, 2009. ,
DOI : 10.1109/ICCV.2009.5459353
URL : https://hal.archives-ouvertes.fr/hal-00473262
Power laws and inverse motion modeling: application to turbulence measurements from satellite images, Tellus-A, vol.64, pp.1-24, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00670364
Variational fluid flow measurements from image sequences: synopsis and perspectives, Experiments in Fluids, vol.28, issue.4, pp.369-393, 2010. ,
DOI : 10.1007/s00348-009-0778-3
URL : https://hal.archives-ouvertes.fr/hal-00456162
Determining optical flow, Artificial Intelligence, vol.17, issue.1-3, pp.185-203, 1981. ,
DOI : 10.1016/0004-3702(81)90024-2
A New Approach to Linear Filtering and Prediction Problems, Journal of Basic Engineering, vol.82, issue.1, pp.35-45, 1960. ,
DOI : 10.1115/1.3662552
Small-Scale Structure of a Scalar Field Convected by Turbulence, Physics of Fluids, vol.11, issue.5, pp.945-963, 1968. ,
DOI : 10.1063/1.1692063
Large sample asymptotics for the ensemble Kalman filter, Handbook on Nonlinear Filtering, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00744737
Scale-space theory: a basic tool for analyzing structures at different scales, Journal of Applied Statistics, vol.21, issue.1, pp.224-270, 1994. ,
DOI : 10.1080/757582976
An iterative image registration technique with an application to stereovision, Int. Joint Conf. on Artificial Intel. (IJCAI), pp.674-679, 1981. ,
Simplified models for turbulent diffusion: Theory, numerical modelling, and physical phenomena, Physics Reports, vol.314, issue.4-5, pp.237-574, 1999. ,
DOI : 10.1016/S0370-1573(98)00083-0
Over-Parameterized Variational Optical Flow, International Journal of Computer Vision, vol.14, issue.3, pp.205-216, 2008. ,
DOI : 10.1007/s11263-007-0051-2
Stochastic differential equations, 1998. ,
URL : https://hal.archives-ouvertes.fr/inria-00560229
Variational Assimilation of Fluid Motion from Image Sequence, SIAM Journal on Imaging Sciences, vol.1, issue.4, pp.343-363, 2008. ,
DOI : 10.1137/080713896
URL : https://hal.archives-ouvertes.fr/hal-00596149
Data assimilation with the weighted ensemble Kalman filter, Tellus A: Dynamic Meteorology and Oceanography, vol.133, issue.6, pp.673-697, 2010. ,
DOI : 10.1080/01621459.1994.10476469
URL : https://hal.archives-ouvertes.fr/hal-00490840
Highly Accurate Optic Flow Computation with Theoretically Justified Warping, International Journal of Computer Vision, vol.14, issue.3, pp.141-158, 2006. ,
DOI : 10.1007/s11263-005-3960-y
Variational optical flow estimation for particle image velocimetry, Experiments in Fluids, vol.14, issue.1, pp.21-32, 2005. ,
DOI : 10.1007/s00348-004-0880-5
Obstacles to High-Dimensional Particle Filtering, Monthly Weather Review, vol.136, issue.12, pp.4629-4640, 2008. ,
DOI : 10.1175/2008MWR2529.1
Layered segmentation and optical flow estimation over time, Proc. Conf. Comp. Vision Pattern Rec, 2012. ,
Image registration using wavelet-based motion model, International Journal of Computer Vision, vol.38, issue.2, pp.129-152, 2000. ,
DOI : 10.1023/A:1008101718719
Discrete Orthogonal Decomposition and Variational Fluid Flow Estimation, Journal of Mathematical Imaging and Vision, vol.34, issue.2, pp.67-80, 2007. ,
DOI : 10.1007/s10851-007-0014-9
