Wavelets and ill posed problems: optic flow and scattered data interpolation, 1999. ,
The Robust Estimation of Multiple Motions: Parametric and Piecewise-Smooth Flow Fields, Computer Vision and Image Understanding, vol.63, issue.1, pp.75-104, 1996. ,
DOI : 10.1006/cviu.1996.0006
High Accuracy Optical Flow Estimation Based on a Theory for Warping, Computer Vision-ECCV, pp.25-36, 2004. ,
DOI : 10.1007/978-3-540-24673-2_3
Wavelet-based optical flow estimation. Circuits and Systems for Video Technology, IEEE Transactions on, vol.12, issue.1, pp.1-12, 2002. ,
Dense estimation of fluid flows, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.24, issue.3, pp.365-380, 2002. ,
DOI : 10.1109/34.990137
URL : https://hal.archives-ouvertes.fr/hal-00329724
Wavelets to reconstruct turbulence multifractals from experimental image sequences, 7th Int. Symp. on Turbulence and Shear Flow Phenomena, 2011. ,
Power laws and inverse motion modelling: application to turbulence measurements from satellite images, Tellus A: Dynamic Meteorology and Oceanography, vol.28, issue.4, pp.64-2012, 10962. ,
DOI : 10.1198/016214501753168109
Final report on the evaluation of the tasks of the workpackage 2, FLUID project deliverable 5.4, 2007. ,
Determining optical flow, Artificial Intelligence, vol.17, issue.1-3, pp.185-203, 1981. ,
DOI : 10.1016/0004-3702(81)90024-2
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.185.1651
Divergence-free Wavelets and High Order Regularization, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00646104
An iterative image registration technique with an application to stereovision, Int. Joint Conf. on Artificial Intel. (IJCAI), pp.674-679, 1981. ,
A Wavelet Tour of Signal Processing: The Sparse Way, 2008. ,
Numerical Optimization, Series in Operations Research, 1999. ,
DOI : 10.1007/b98874
Global and uniform convergence of subspace correction methods for some convex optimization problems, Mathematics of Computation, vol.71, issue.237, pp.105-124, 2002. ,
DOI : 10.1090/S0025-5718-01-01311-4
Image registration using wavelet-based motion model, International Journal of Computer Vision, vol.38, issue.2, pp.129-152, 2000. ,
DOI : 10.1023/A:1008101718719
Discrete Orthogonal Decomposition and Variational Fluid Flow Estimation, Journal of Mathematical Imaging and Vision, vol.34, issue.2, pp.67-80, 2007. ,
DOI : 10.1007/s10851-007-0014-9
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.529.4121
Simultaneous Higher-Order Optical Flow Estimation and Decomposition, SIAM Journal on Scientific Computing, vol.29, issue.6, pp.2283-2304, 2007. ,
DOI : 10.1137/060660709
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.497.2250
