Minimizing the Reconfiguration Overhead in Content-Based Publish-Subscribe - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
The publish-subscribe model provides strong decoupling among the components of a distributed application. This makes it amenable to highly dynamic environments. Nev- ertheless, publish-subscribe systems exploiting a distributed event dispatcher are typically not able to rearrange dynam- ically their operations to adapt to changes which impact the topology of the dispatching infrastructure. This paper presents a description and analysis of a novel algorithm to deal with this kind of reconfiguration. The strength of this algorithm is its ability to minimize the portion of the system affected by the reconfiguration by exploiting a novel concept we refer to as the reconfiguration path. Simulations compare our approach with two others and show a significant reduc- tion (up to 76%) in the overhead caused by reconfiguration.
Fichier non déposé
hal-00739607 , version 1 (08-10-2012)
  • HAL Id : hal-00739607 , version 1
Gianpaolo Cugola, Davide Frey, Amy L. Murphy, Gian Pietro Picco. Minimizing the Reconfiguration Overhead in Content-Based Publish-Subscribe. Symposium on Applied Computing, Mar 2004, Nicosia, Cyprus. ⟨hal-00739607⟩
41 Consultations
0 Téléchargements
